My laptop is not starting up normally,asking for startup repair but i hv no back up and no repair disc.i tried to reinstall previous operating system w7 ultimate in the option install a new copy but window has not finds any partitions of hard disc to install it.pl suggest what should i do?this trouble doveloped when i tried to uninstall and reinstall a software folder lock in pc.
  • 302 Answers
Since you have the Windows 7 Ultimate CD, you can just reinstall the whole operating system.
First insert the cd on the drive.
Restart the computer, wait for the option to (Press any key to boot from cd) then do that.
Let Windows gather files for installation then when prompted as to where you are going to install Windows, you can do a quick format and you can also make a partition on your hard drive.
Then after you have formatted and made a partition, just follow the instructions for the installation of Windows.
Posted on Mar 12, 2011
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
Windows will not start up or launch start up repair
hi,
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
Computer turns on and after its done showing loading bar a blue screen appears . the computer then restarts with a black screen showing start windows normal, or startup repair. i chose startup repair
Try running the Check Disk Utiltiy.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 25, 2012 | Computers & Internet
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
When I turn on my asus it goes to a screen with two options: start normally or launch startup repair (recommended). i have tried clicking both of these options and with the former i am sent to a black...
There are errors in the operating system that's why it's not letting you to get into the operating right away. It's asking you for the Operating System reinstallation disc. If you have the disc, insert it the dvd player and restart the computer. The Disc will automatically be detected and the computer will ask you to press any key to boot to the cd. Just press any key. It will then bring you to the page which will ask you to install or repair. Just select repair and let it load. Follow the on-screen instructions. It usually work except if the operating system is seriously messed up. If no go, you don't have any other choice but to do the operating system reinstallation. But the operating system reinstallation will erase all the files and documents that you have in your computer.
If you can still get into your operating system, back up all the files and documents which are important by saving them in an external hard drive or a USB flash drive. After backing up those files, do the complete reinstallation of the operating system.
Click on the correct operating system that your computer is running in the choice below so that you will be directed tot the guide that I made.
1. Windows Vista
2. Windows 7
3. Windows XP
Thank you for using fixya.com
Apr 10, 2011 | ASUS Eee PC 1015PEM-PU17-RD Netbook
My son accidently shut his laptop down whilst installing microsoft office and now he has an error on startup: status: oxcoooooe9. I tried rebooting and starting in safe mode but it always goes back to...
Instead of re-installing the Operating System you can do an Operating System repair. Boot to the Windows Operating System installer disc,. If you have XP, boot to the XP installer disc then enter the setup program. There will be an option that says "Press R to Repair Computer". Press letter R then let the setup finish. For Vista/7, boot to the installed disc then select "Startup Repair" This will repair all corrupted Windows file and will keep your data intact,
Hope this help.
Mar 26, 2011 | Toshiba Satellite L305-S5908 Notebook
A Windows Update seemed to have crashed my laptop
I"d go back and reboot and when it asks you that question again press start windows normally.
Jan 09, 2010 | Computers & Internet
Upon startup i get an error: configFree has stopped working. I run the virus program Norton 360 but it says no virus. before this i was installing an application and it gave me the "you need to be the...
I would reinstall your operating system fresh after doing a full format, remember to back up your hard drive. I have never had satisfactory results from any virus scanner or system restore.
Oct 26, 2009 | Toshiba Satellite M45-S265 Notebook
Error code at startup
Re: windows Vista will not start I had the same problem and came across this solution that worked for me as well: 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Apr 11, 2009 | Computers & Internet
Will not start up normally (freezes )
it sounds like the operating system has gone corupt so have you got a disc to reinstall windows and all the drivers!if you have i would format the harddrive and reinstall the copy of windows
Oct 30, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
