Question about Velocity Tablets & eReaders
I Cant reset my cruz tablet?i forgot my password
ginko
  • 19396 Answers
SOURCE: How do I do a
Hi.
Press reset hole button using a paperclip, then hold down volume + button until 'Cruz' appears on display. That will reset the tablet.
Posted on Apr 29, 2011
byteguy
  • 2229 Answers
SOURCE: forgot password
Tablet PCs aren't my specialty, but as long as you are running Windows XP. it should work like any other version of Windows XP.
Start up in safe mode and log on as administrator. If your computer is like most others, whoever set it up forgot to password protect the administrator profile. If so, you can log on as admin and go to users and change your password.
Good luck.
Posted on Mar 05, 2009
SOURCE: my cruz tablet wont work only appears cruz on screen when i power it on.
george,have you gotten a solution yet? mines is doing the same thing
Posted on Dec 07, 2011
  • 37 Answers
SOURCE: when turning n the cruz tablet, the word cruz pops up and goes away. then cruz flashes
First don't worry too much you're just stuck in a loop or have bad firmware (most likely). The fix is probably going to be easy but you have to do some things. Just follow the directions I give and that Velocity gives and you should have no problems in about half an hour.
Take out the top SD card. Put in in your computer or an adapter that goes to the computer.
Go to the cruz website and download the current firmware (http://cruzsupport.velocitymicro.com/ics/support/KBAnswer.asp?questionID=814).
Even if you have updated the ROM something could have happened and it could be corrupted so replace it. Put that firmware on your sd card. Do not extract the zip file. Do not change its name. If the name changed (like if it has (01) at the end) delete the old file you downloaded and change the new one back to the old name.
Eject your sd card when you finish and put it in your tablet.
Press the top power button and the up volume button at the same time. Continue holding. You will see cruz but dont stop.. it'll flash kinda and it'll still say cruz.. keep effin' holdin'...
the robot shows up: you win! let go relax give it some time to freshen up. Have a cup of coffee and let it finish. Everything will be tidy and new when it's done.
the robot doesn't show up and the same thing that's been happening happens again: try pressing reset when it turns on (paper clip in that hole youll feel a button when you get it right). Keep pressing it the whole time it has power to try and get a hard reset. Do it like 2 or 3 starts and fails just for good measure.
then try to flash again (power and volume up).
if that doesn't work pull the back, unplug the battery and wait 30 seconds to a minute. plug it back in and try flashing the first time you start up. like don't press power hoping its going to turn on now. It won't. You have given it a clear quick access memory which may let you get to the point where you can flash without failing.
IMPORTANT: On the first time after the battery is plugged in hold power and up volume together and keep holding. This is important. If you press power it will recurrupt the RAM and you made the back lose and unplugged the battery for nothing.
If that doesn't work.. well it should. You're stuck in a loop that you should be able to pull out of. Go back the the beginning and make sure you have the new file you downloaded and the name is correct (its on the cruz support website).
If that's all done properly try the battery thing one more time. If it's still failing don't give up.. give it hell. I was stuck in a bad one going strait to white screen only being able to shut it off by pulling the battery and I was able to get it to flash (took about 30 tries). For the trying at this point you don't have to pull the battery just keep starting it with power and volume up pressed.
As long as you're not staring at a black screen you should be able to fix this.
Good-luck!
Posted on Dec 13, 2011
tengzong0214
  • 21 Answers
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
Posted on May 28, 2012
Forgot my password
reset your phone in devoleper mode.
Nov 18, 2013 | Velocity Micro Black Cruz T301 2gb Wi-fi...
How to unlock
Depending on the firmware revision you may be able to reset the password through Google Authentication so first your tablet must:
1. Have been registered with a Google Account
2. Be connected to the internet
3. Have the latest version of Cruz Reader Firmware
If the above is try, try the following to reset the pattern:
1. Try to unlock the pattern 3 to 5 times until you see "Forgot Pattern" pop-up
2. Click on the "Forgot Pattern link
3. Follow the steps to reset the pattern
Jun 06, 2013 | Tablets & eReaders
Forgot password for tablet
Reset windows password not a problem any more nowadys.
The easiest way to reset a forgotten Windows password I ever use is to use Windows Password Reset ,just a few steps:
Hope it can help you
May 22, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
I forgot my lock pattern on my cruz reader
If you are running Android on the Cruz Reader and you have set up your Gmail account on it, then the reset is pretty simple. If you enter the pattern incorrectly several times, and option will come up for resetting a forgotten password. If you select this option, it will ask you for the username and password to the Gmail account that is set up on that device. Hope this helps and good luck!
Mar 03, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
Tablets & eReaders Logo
290 people viewed this question
Top Velocity Tablets & eReaders Experts
steve morris
steve morris
fred capra
fred capra
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
