This looks as if its a newer model laptop. If it's w/in a year old, I would contact tech support as it may be hardware issues or a loose connection. They should be able to take you through troubleshooting steps. Otherwise, they may have you send it in for repairs.
It should work if you start the program C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControl.exe
alanzis is a genius <3
Hi
No keyboard lights mean that POST isn't running. POST is the power on self test where the computer tests the keyboard and video.
Is this a new build or a store bought PC? Added any hardware recently?
Make sure that the power cable is firmly plugged in. Press it as hard as you can, sometimes they require a lot of force.
Also you may want to remove the CMOS battery to reset the hardware info. Open up the case after you disconnect all cables. Hold the power button to drain the power. Take out the large, round battery on the board. It has a clip near it to release it.
Take it out and put it to one side. Pop it back in after ten minutes and see if that helps.
However if this happened after adding a new graphics card, remove it and use onboard if possible. Some graphics card because this problem but you can turn the PC on after about 10 or 15 minutes .
Please get back to us if you have further query else please accept the suggestion.
