The agitator in my washing machine is trying and notting all of the clothes up, resulting in the machine becoming unbalanced. I have taken the lid off and wached what happens and the agitator only seems to be spinning in one direction. Is this normal?
    Scholar:
  • 106 Answers
Is this a GE Washing Machine? This sounds like one, it sounds like the shifter coil has failed, this it's not locking to engage the agitator. So it's basically stuck in spin mode, this way, even though the tub does not turn.
Posted on Mar 12, 2011
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
My washing machine turns on but wont rinse my clothes
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 09, 2009 | Avanti 10 lb. Portable Top Load Clothes...
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Machine wont agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 19, 2009 | GE WDSR2080D Top Load Washer
Will not adjatate
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 01, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer does not spin
that wont cause it not to spin but it just jerks the tub around a bit stronger.you most likely have a bad clutch.you can take front panel off and see if your clutch is grabbing when you put it in spin.it is under the motor.
Mar 12, 2009 | GE WBSR3140DW Top Load Washer
My washer wont agitate ?
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Feb 07, 2009 | Maytag Performa PAV2200
Washing Machine Shaft Wont Move
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
