Question about Dewalt 7.2-18.0 Volt One Hour Charger
The charger inidcated to replace battery. I did this and purchased two new batteries. I Have attempted to charge them but get the same LED indicator to replace the pack. How can I test the charger or is just faulty.
  • 3,400 Answers
If you have a Batteries Plus store near you they can test your charger. (had one done recently)
Posted on Mar 12, 2011
  • Steve Nordquist
    Steve Nordquist Mar 13, 2011
    Well, unless you bought batteries from a really shifty seller, it's clearly faulty.
    You could possibly fix it by removing salt, corrosion, etc. where you find them, open-circuit testing discrete components, dropping it by the local DeWalt Warrantee Enforcement Corps of Engineers etc.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Battery charger flashing red
Although the manuals nothing says about flashing red light on charger, my best guess is the battery is defect.
Try to remove the battery several times and start the charging again and again. But when after a few attempts the LED starts flashing again, you better buy a new battery. When you don't use the camera for a longer period, make it a habit, to charge the battery every 3 months or so.
Jan 13, 2014 | Olympus Stylus 850SW Digital Camera
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
Dec 11, 2013 | Black & Decker Black and Decker 18V...
We have a pride jazzy 1143 select power chair. we have had problems with the batteries going bad. I purchased a new set of batteries last December. in June they would not hold a charge and I purchased a...
charger is no good or is not the correct charger for that chair suggestion have a dealer tech replace a original charger in chair,it should have a 3 yr warranty anyways
Oct 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Mini 1012. new battery. charger led working, battery wont charge. when plugged in charger works for about 30 seconds
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
Jan 28, 2013 | Dell Inspiron Mini 1012 Netbook...
Battery charging does not function
The rechargeable battery is bad or the charger has malfunctioned. Take to a camera shop and have them check it out before you purchase a new battery.
Jul 07, 2012 | Genius G-Shot DV610 Digital Camera
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
I purchased a Schumacher 1200A battery charger a few months ago and just last night tried to charge my 2007 Infiniti G35 battery. The vehicle gets limited use and when I went to start a week ago the engine...
I don't think you did anything wrong. I think your battery is tired and can't take a charge deep enough as it used to. As batteries get older and after repeated discharge and recharge during normal operation, they start losing their ability to hold charge as deep as when new. This is gradual and after a couple of years they drop to 50% and less. I think your attempt was "gallant" and you did everything correct, but it sounds that battery has flatlined on you and "Doc, the patient is gone"
Jan 05, 2011 | Schumacher & Fast Charge Starter Charger
14.4V Charger doesn't work
This must typically be the Batteries themselves in the Drill. Usually, rechargeable batteries give out after a couple of charges, if it has handled few charges, then it must be a fault within the Charger. But I'm sure a battery replacement would be fine :)
Apr 02, 2010 | Skil 14.4 volt Drill with Built - in Stud...
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
Dewalt 7.2-18.0 Volt One Hour Charger Logo
389 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
