Question about PfaFF Tiptronic 2040
I inherited my mother's Tiptronic 2040, and needed to sew a simple seam. I admit to not having much experience. I have re-threaded it several times,; re-worked the bobbin but the top thread keeps getting jammed inside the bobbin area. The needle will rise twice (making 2 stitches), then locks up, stops, and I have to open the bobbin area to struggle to get the tight thread removed.There is no information in the manual to explain what I may be doing incorrectly, in fact I'm disappointed in the manual as a learning tool. Yes, I need some lessons...but can I get some help to get this one seam...PLEASE?!
  • PfaFF Master
  • 1,564 Answers
Deep breath. Ohmmmmm.... ok now.
Few things you need to know.
1. Try to remember TTN when you run into problems like this it stands for Thread, Tension, Needle. Contrary to popular belief, there is no such thing as universal thread and needles. You'll need to determine what kind of thread and needle is best for your application.
2. When things gets bunched up under the fabric it Usually means that the tension for the top thread is too loose. However, a bad, bend or just plain wrong needle will cause these problems too.
3. Always grasp the threads (both top and bottom) and pull gently backwards when starting a seam. Some old school seamstresses and seamsters say to make sure your needle is at its upper most position (just before it starts to move down) before you begin sewing.
4. since you've had a couple instances with this issue... you might have to clean the bobbin race area. I'm a bit reluctant to tell you about this but remove the bobbin and look carefully for other stray threads, dust bunny's etc.
I hope this helps some. ;o)
S
Posted on Mar 12, 2011
I have a pfaff 2030/2040 tiptronic. I have had the timing repaired 3times. Will this be a continuing problem. Is it time to replace my machine?
Take it to a different technician. If it is irreparable a good tech will tell you. It is most likely the timing belt tension or a loose screw (or two) on the hook. Once set properly and secured it should hold. If you are attempting to sew too thick of a seam it could jar the needlebar out of position as well.
Dec 09, 2016 | PfaFF Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
I have a pfaff 2040 tiptronic and the bobbin thread keeps bunching up and stopping the machine
Here are a couple of solutions to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
Note: When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Dec 22, 2009 | Sewing Machines
Threading the machine
what is the setting to hem
Feb 21, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
177 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
