Question about Panasonic PT-47WX42 47" Rear Projection Television
I have a Panasonic projection TV with a blown resistor (R7116) and possibly some IC's that need replacing. I'm going to replace the resistor 1st but I cant id the value or part number. Image of similar board: http://www.thewilsonclan.com/Forsale/53_IC.JPG Third resistor from the left (R7116)
  • 84 Answers
2.2 ohm, 1 watt resistor
Bill W
integrityhomeworx.com
Posted on Mar 14, 2011
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
2.2 ohm resistor blowing after convergence repair
It might be the issue on the board. I would recommend you to show it to a repairman
Sep 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Looking for resistor value on Toshiba PB7243 Power convergence PCB Resistor is R7731 part of bias for convergence IC I think.. but looks burnt
R7711, R7721,
R7116, R7726, R7736, and R7731. are MF, 1.2 ohm, 2W resistors--MF means metal film or metal oxide--check all of them if you are replacing the two STK-392-110 CHIPS---
They are protect resistors in case some part of either chip shorts--if even one is bad--you need to replace both chips at the same time and adjust.
If you need help or advice let me know--I am here to help.
If this information helped you rate this solution as I do this here for free.
SD TECH
Jan 02, 2010 | Toshiba 55H70 55" Rear Projection...
Detailed problem per your response
The problem is that the ICs may have been blown because the resistors were bad. Just as a double check before you replace anything else. Please confirm that the STKs are STK392-110. Also, replaceing them with STK392-150 is a valid upgrade, I'm not sure about the 180s, but I'll check. Both the STKs and the resistors need to be changed at the same time.
The hour glass view you reported: Was the bowing on the top and bottom or on the sides?
Thanks,
Dan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Continued convergance issue.
I have heard from a few people that the higher value IC (150, 180, etc) do handle more current, but also that they *draw* more current, as well. Taking a guess, it may be simply that the 180s you installed were pulling too much juice from the resistors, which is why they popped. These ICs were used in many TVs, so it may be that the Panasonic doesn't have as much tolerance for the 180s' power requirements as, say a Hitachi.
Luckily, resistors are pretty cheap, so it's probably worth the few bucks to replace the resistors when you drop in the 110s you have in hand.
Sep 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Failed resistor
those are the convergence feed resistors. # blinks on a panasonic means convergence IC failure. You will need to replace the two stk392-110 convergence ICs and the six resistors. You can get replacement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Sep 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
May 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Need help with color on panasonic hdtv
Convergence circuit repair needed.....Requires chassis pull,
IC replacement and check / replace current limiting resistors.
T.
Apr 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Replaced IC chips and fried something
1)WHICH chips?? 2)Which resistors? (locations) 3)It is worth it. 4)Possible,but usually not needed.
Sep 19, 2007 | Panasonic PT-53WX54 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
