Question about Dahle High Security 20634EC Shredder
Jam light comes on but there is nothing in the shredder
The jam light flashes and the warning beeper beeps, but there is nothing in the shredder. Is there a simple way to clear this problem?
  • larsondh Nov 07, 2008
    I have the exact same problem... i have tried turning it off and unplugging it waiting and then re-energizing the equipment and i have also tried cleaning the entire set of internals on it and nothing seems to work.
Take the plastic top off of it by removing the four silver screws (two front two back)
in the upper left there is a circuit card that the top of the shredder is connected to by a ribbon cable.
ensure all the cables are plugged in (there is a small black plug near the top that has a habit of coming loose it seems).
If they are all plugged in, disengage them and clean all the connectors (i recommend using rubbing alcohol) and then plug them back in, test to make sure that everything is working before screwing the lid back on completely.
and as a final note: i highly recommend making sure the shredder is unplugged from the wall socket prior to opening it up to work on it, as with any energized equipment keeping it off while poking around inside of it is always a good idea.
Posted on Nov 07, 2008
  • cmin7b5 Aug 06, 2014
    Have you noticed if the speed sensor tends to fail on these models? Mine is having the same problem, but the plug connections are definitely solid.
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
Staples TXC22A. Why does Jam Light prevent shredding?
Your meticulous cleaning may have overlooked embedded residue from coated paper or paper laminated with plastic. It may be necessary to use a sharp pick and even a utility knife to remove the material bit by bit.
Feb 05, 2013 | Office Equipment & Supplies
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
Jul 06, 2010 | Fellowes PS60-2 Shredder
Shredder Beeping
The motor would always turn the cutters.
You likely have a broken chain or a loose gear on a shaft. If you hear the motor running and the cutters are not spinning something in the drive is broken. Likely the chain.
hope this helps.
Mar 20, 2009 | Dahle High Security 20634EC Shredder
Ccs-1500
The solution is to remove the paper bin, and dig out the jam.
1. Unplug shredder
2. Remove paper bin
3. Lay it on it's side or back
4. Dig out all the paper around the teeth
5. Put paper bin back in and plug in
6. Should be good to go
Nov 15, 2007 | Achiever CCS-1500 Cross-Cut Shredder
Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Jun 03, 2007 | Shredder 1052 (Cross-Cut)
Dahle High Security 20634EC Shredder Logo
424 people viewed this question
Top Dahle Office Equipment & Supplies Experts
jhnolson
Dennis Key
Dennis Key
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
