Question about Answer Carbon Expert BMX Handlebar
I want to know the cost of red tacton device - Answer Carbon Expert BMX Handlebar
In india the cost of redtacton device is near about 80,000rs......
Posted on Apr 02, 2011
If I order the pebble smart watch from the get pebble site, how much will it cost to ship overnight with fedex?
If you order the pebble smart watch from their site, it says it will cost you $25 to ship overnite.
Mar 06, 2014 | Pebble Plus Smart Watch for Select Apple...
How do i program my ge tv remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 17, 2012 | Memorex MLT3221 32 in. LCD TV
What does trouble code "SC
Hello Ryan,
It means your device went thru a self check in an effort maintain optimum copy quality. Your device could not get Magenta (pink/red) to even get close to the target values for that color. The most likely cause (and we hope so) is the Magenta development unit is toast. Replace it. But of course there are a myriad of other fun causes. As a sidebar, you might want to consider replacing yellow and cyan at the same time as they tend to croak at pretty much the same time. You have a quite reliable device as a rule. It's worth the cost. Take care. Let fixya know I helped ya please. SPINAL
Jun 18, 2011 | Ricoh Aficio 2228C Copier
Power light red on AT&T 2wire modem for DSL.
This may be a dead modem situation. These things happen. They can come from several causes. Either you overheated your modem (was there something on top of the ventilation ports, was liquid spilled on it while running, do you smoke? [it effects electronics more than you know], or did it simply go out of date? [check for firmware updates]). Generally when an electronic device gives you the big red finger (that light) it means it is dead. If you want to attempt any sort of fix (which I would consider futile as most likely a large company like AT&T just said "flash burn the firmware and make them buy new hardware" you would look for key signs of electronic trauma. Things like burnt wires, capacitors, resistors. You can see these easily as either a wire has burnt so bad it no longer connects or a resistor (generally brown in color with 3 colored bands to dictate it's resistance) being burnt with no color in the bands or a capacitor (can looking device) that is bloated. These devices could be manually replaced, but that takes at least an A++ certification and knowledge of the device you are working with. At this point if you are bold, there are no consequences because the device is already broken. If you can revive it, congratulations. But the reality is your modem is now obsolete and you simply need to replace it. It is the nature of ever evolving technology. Your VHS can't play DVD's. However it is happening on an vastly excellerated scale.
Aug 20, 2009 | 2wire Computers & Internet
OLEVIA 37 IN,NO RED COLOR
if there is no red color on the television, it could be a connection issue.. or just a main-board problem. First you have to try different devices to see if it happens with anything your watching.
If it only happens with one device it could be the cable or the device it self..
Usually missing red color appears when using bad component cables or simple as a cable not connected in the correct port.
I know this company Amergence Technology is still helping out olevia customers to troubleshoot any problems they have or if there is a problem with the television they could give you an idea on the repair cost. there number is toll free 866-965-3842
Jul 01, 2009 | Olevia LT37HVS 37 in. LCD HDTV
What size batteries for my tasco propoint, built 1985
Tasco's Contact Information is here
Thier website didnt have an information on scopes that old that i could see. however if you contact them im sure they would know what size the battery needs to be, and would be happy to refer you to a place to purchase them (if not a product they themselves supply)
NOTE Tasco is a European company residing in Spain Madrid. You may be asked to send it overseas to be identified? (worst case scenario) if this is the case be sure to purchase a number of batteries for the device to make it somewhat cost effective
:) (I couldnt find the battery type as i dont know exactly what scope you have :(
Brad
Apr 11, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
USB Mice don't work @ all
GO INTO CONTROL PANEL AND OPEN UP DEVICE MANAGER AND CHECK FOR ANYTHING THAT SHOULDNT BE THERE, LIKE CHECK MARKS, YELLOW, RED, ORANGE,
RED XX, CLICK ON THE DEVICE.
IF THAT IS OKAY GO INTO CONTROL PANEL TO SYNC THIS IS FOR PLUG AND PLAY DEVICES LOOKING FOR ANY MARKS THATR SHOULDNT BE THERE.
CONTROL PANEL LOOK IN PROBLEMS AND REPORTS, CHECK FOR ANY INFORMATION THAT THE SYSTEM MAYBE HAVING ANYTYPE OF CONFLICKS AND IT WILL ASK YOU IF YOU WANT TO RESOLVE THE PROBLEM ONLINE OR OFFLINE, DO THE ONLINE IT GOES TO THE MANUFACTURE AND IT DOESNT COST YOU A PEENY.
ROD
Feb 25, 2009 | Logitech Mini Optical Mouse
No red in my KF-WE610 picture
Color wheel could be problem dont know cost but light engines cost 1,200.00 up to 1.900.00
Sep 22, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Red color slide on left side of 43UWX10B
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Aug 05, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Answer Carbon Expert BMX Handlebar Logo
95 people viewed this question
Top Answer Cycling Experts
Indermani Tiwari
Bill Boyd
Donald Ayers-Marsh
Are you an Answer Cycling Expert? Answer questions, earn points and help others
