Question about Makita K06 Switch 5007fk 5007nb 5007s Circular Saws
My blade to my circular saw model number 5007nb was having trouble cutting through some wood which lead to it over heating how can i fix this thing and get it to start working tonight
  • 2,019 Answers
Well you did not really say what is wrong?
Are you trying to stop the overheating, or did it get so bogged down from blade heat warpage, that the internal circuit breaker tripped?
If so, then look at the end of the motor, near the cooling vents, and press the little black circuit breaker reset. (not all have them)
Also check that the outlet still works, by plugging something else into it, because you may have tripped the circuit breaker for the outlet, or GFP.
Posted on Mar 12, 2011
How do u life up the saw sleeve (the thing u move to cut the wood) on my Kobalt 10-in 15-Amp Sliding Compound Laser Miter Saw
If your saw is completely intact, meaning no missing or damaged parts, the blade guard should rotate out of the way of cutting as the saw head is lowered to make a cut. You didn't give your model number but there should be a push rod or link plate from the pivot point on the base to the blade cover that pushes the guard out of the way as the head is pivotted downward. If you have the cutting head locked down to make sliding cuts the guard should be up and out of the way. If this isn't happening you may have broken or missing parts of the guard system.
Feb 17, 2013 | Saws
I have dewalt 18 v circular saw i cut vinyl lattice once and used it on a 2x4 but it wouldnt cut it, started to cut then just stopped. is blade dull already? new saw.
a couple things to look at. Did the saw stop operating or was the blade not wanting to cut. Remove the battery and CAREFULLY feel the blade for dull or broken segments. If the blalde stopped check to make sure not a loose bolt holding it on. Did you reverse the blade for cutting the vinyl. Let me know more information and I will try and help
Feb 02, 2012 | Dewalt 18 V Cordless Circular Saw Model...
When sawing against a guide the back of saw moves away from guide can not hold it against it. Also center of blade around arbor gets hot and builds up gum. no looseness in bearing and saw turns free???
hi there
this happens alot with circular saws it usually means that the saw is out of alignment back to front this makes it ******* the tool because your going strait and the tool isnt its fighting it self ******* the motor and whole tool this happens easily setting it down hard throwing it in truck with other tools etc.. the olnly thing you can do to fix this is use solid work bench with tool unplugged lift safety set blade up against the bench then measure front and back from the bench this will tell you if its out of line if so you will need to take it to a tool repair shop to get it fixed
hope i have helped you with your problem thank you have a great day
Aug 20, 2011 | Makita 7 1/4" Circular Saw 5007NB
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Cord replacement on skill saw model # 5007nb
the cord set you need is 664463-0, the wire guage is 2x14x8 SJ any repair shop should be able to help you with the proper wire guage cord for this tool. The installation is really easy after removing the handle half
Nov 05, 2009 | Makita 7 1/4" Circular Saw 5007NB
Saw runs only after u turn the blade backward by hand 2 turns ?
You probably have a brush problem, Unplug the tool and remove the brush holders and check the condition. Give me the model number and I will try and get you a breakdown for this tool.
Aug 26, 2009 | Makita 7 1/4" Circular Saw 5007NB
Makita Circular saw 5007NB, the cutting depth guide is jammed. What can I do?
you can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
Jul 01, 2009 | Makita 7 1/4" Circular Saw 5007NB
Cover will not come up to cut wood
K looked at a breakdown for this tool and it sounds like you are missing a shoulder bolt or roller with bolt that attaches to the lever. Try pulling the guard up by hand (unplug saw first) and watch the side where the cover is for the movement of the lever. Try and locate where it is jumping or the missing part. You can look at the same breakdown at Searspartsdirect.com and by typing in your model number it will come up. It is not really that clear but you will get some idea how the lever/guard work. Let me know if you still have trouble
May 24, 2009 | Craftsman Saws
Makita K06 Switch  5007fk 5007nb 5007s Circular Saws Logo
157 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
