Question about Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
    President:
  • 1,554 Answers
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Posted on Mar 12, 2011
F22 error persists on my washer, does the door gasket have to do with it?
F22 is usually a door latch error on Kenmore washers so you are working on the right area. The door gasket rip should not cause that unless it is stopping the door from closing all the way. It is usually the door latch itself which has switches built into it that causes that error or the main board is not reading the latch operation.
Mar 21, 2015 | Kenmore 4.7 cu. ft. High-Efficiency Top...
Code f22 flashing when i try to start load. the door seems to lock fine
unplug washer and let set 30 min. should reset. plug in, turn on then turn off a couple of times to see if doorlocks and unlocks properly. If not you may need a new switch. That F22 is door lock malfunction. You may need to check hinges and see if they are tight.
Jul 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
Whirlpool Duet Ht Problem: Code F22 / Door locked I have unplugged the machine for a 1/2hr and still doing the same thing...
Hi
To unlock the door press RINSE HOLD to manually terminate the cycle. If this doesn't unlock then unplug the washer and try this 1-2 times.
Alternatively try holding the start button to check whether you are getting any error message. If there is no error message then you would need to replace the door latch or check the wiring to the door latch.
To manually unlock the panel first you'll have to Unplug the Washer from the power outlet. Now, remove the lower toe panel. Look for the bottom of the door latch assembly from inside the washer. Check for a tear-drop shaped tab and pull the tab until click is heard, door will now unlatch. Hope this helps... Please post back for further assistance.
Daniel
Nov 16, 2010 | Whirlpool Washing Machines
What does an f22 error message on my Maytag 3000 series washer mean?
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Nov 01, 2010 | Washing Machines
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I unlock the door of my kenmore Elite H4t front load washer
If the door is locked or jammed and will not open, you can first attempt to unlug the washer for at least 30 minutes to reset the Central Control Unit (CCU). Sometimes the door will become locked if the program gets interrupted during the wash cycle and may just be a momentray glitch. If the CCU reset does not work, there is a manual release you can use to open the door. The following link epxlains:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
Often, simply using the manual release will reset the door latch and the washer will return to normal operation. If there is a problem with the door latch circuit, there will usually be an error code of "Fdl" or "F22" on the display (depending on model number).
If your washer exhibits any of these errors, the problem is associated with either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
The procedures are the same for an "F22" error. I have included parts resources, if required, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
May 11, 2010 | Kenmore Elite 45986 Front Load Washer
Close door, f22 message, won't start
"F22" is a door latch error. The following link explains:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Read through all the steps listed and let me know if you still require assistance. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,435 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
