Question about AT&T Sony Ericsson W580i Cell Phone - White
My sons phone does not slide smooth like when it was new. he probably has gotten dirt in the tracks. is there anyway to clean it?
Go to wallmart and buy a bottle of air and stick it in the phone and get it all around in the phone
Posted on Aug 04, 2008
Sliding gate pauses and shakes when it first starts, both opening and closing. Does this for a while, going very slow, then smooths out and closes and opens ok.
most sliding gates suffer form dirt, grass , rocks in the gate track so constant cleaning of that track is essential
small twigs , rocks will slide along with the wheels on opening but are an obstruction for the wheels on closing
most closing gates run a cog and rack system at the bottom ot the gate so check that the mesh of the rack and cog is correct at either end
Jul 26, 2016 | Cars & Trucks
Sim card rejected mobile no.9592607262
Locate the SIM card on the phone. Generally the card is stored under the battery. You'll probably have to remove the back cover before you can slide out the battery. Be sure the phone is turned off before doing this.
Remove the battery and look for the SIM card. It is usually white or yellow with circuitry printed on it. Sometimes it has text on it as well. The card may be as small as a thumbnail.
Remove the SIM card, which is usually held in place by a metal clip. To unlock the clip, lift it up or slide it up or down. Gently lift or slide the SIM card up and out of the clip. You may need a pair of tweezers.
Blow around the area where the SIM card had been lodged to disperse any dirt or dust.
Look for any water, dirt or grime that may have gotten into the phone or on the SIM card. Use a soft cloth to gently wipe the SIM card, the battery and the area around the SIM card compartment. Make sure to use a fine cloth that will not tear or catch on circuitry and other metal parts.
Inspect the SIM card for damage such as cracks. If the SIM card appears undamaged, firmly return it to its home in the clip. The SIM card circuitry should be face down so that it is touching the metal connectors on the phone. Slide the clip back into place to secure the SIM card.
Replace the battery and any casing. Turn the phone on. If the SIM card has been cleaned and properly placed back into the phone, it should function properly.
Contact your cell phone service provider if the SIM card is still rejected. You may need to replace it.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 14, 2011 | Computers & Internet
I installed a new bathtub bypass shower door and the outside glass doesn't slide smoothly. It seems to bind in the middle of the bottom support track; it moves, but not as freely and quietly as it should.
Please clarify - you said it's a pivoting door but also said it doesn't slide smoothly - can't really do both at the same time. If it's a typical bypass sliding door then you should be able to make an adjustment to the hanging brackets on the offending door to raise it up off the track. If all else fails the header track can be raised thereby making the doors hang higher and off the track attached to the tub surround.
Oct 28, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
The motor has a large electrical arch and burns when it is turned on. Is there anything I can do to fix this?
Usually there is some dirt that has gotten into the motor compartment and is making the brushes arc. You can make sure your vacuum is unplugged and lay it on it's back so you can see the bottom part of the vacuum where the roller is. There are about six screws in the bottom that need to come out. They are all the same length so you don't need to keep track of where they came from. When the screw are out the bottom will easily separate from the top. Now you can get a better look at what is going on and clean out the sand etc. If there is a lot of dust and dirt than your fan housing is probably worn out and may even have holes in it. If cleaning it out doesn't help than it requires more service than you can probably do and usually it costs too much to fix it unless you are really attached to the machine.
Feb 03, 2010 | Oreck XL2000 Bagged Upright Vacuum
Sunroof won't operate
Sun roofs all have a common problem in design...Ther are all on the roof...and exposed to rain, dirt, dust, etc. etc. Your sliding tracks are probably clogged with the above mentioned and are causing a binding in the track sleeves which makes the motor work much harder and causes the motor brushes to overheat and stall or burn up completly. Next time the motor is replaced, make sure the technician thoroughly cleans and properly lubricates the tracks, sleeves, and guides.
Aug 18, 2009 | 2006 Ford Escape
Automatic sliding door does not close correctly every time. It stays slightly ajar. Local mechanic told me it is out of alignment, local Nissan dealer told me I need a new motor. I think the local mechanic...
The first thing to do is clean out the track the door is running in with a rag from dirt and foreign matter then lighly lube the track like put some wd 40 on a clean rag and wipe it in the track,also spray wd 40 or equivilant in the latch area.
Aug 05, 2009 | 2004 Nissan Quest
My screen on my sidekick slide wont slide smoothly
ur bolts are loose u will need to get it fix and u will need to not flip it alot that is wat causes it
Apr 29, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Casio exilim EX-Z700 lense won't open to take pictures
Hi there and thanks for coming to FixYa.
90 percent of the time, it's dirt, sand or grit that has gotten into the lens mechanism preventing it from opening properly. Try this:
Take an air compressor if you have one, or maybe you can use a friends, anyway, put the nozzle up to the camera and run it around the space between the lens and the camera to clean out any dirt or yuk that may have gotten in there. Best of luck. Leave me a comment if you have any other questions.
Rob
Feb 24, 2009 | Casio Exilim Zoom EX-Z700 Digital Camera
Slider is become rough
Gently wipe the tracks down with a cuetip or cotton bud to take the grime and dirt out of it then lightly with a lead pencil rub up and down the tracks
Nov 06, 2007 | Samsung SGH-D900 Cellular Phone
AT&T Sony Ericsson W580i Cell Phone - White Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
