Question about HP Photosmart C4100
Error code 322 - HP Photosmart C4100
  • 62 Answers
Hello
Unfortunately an "error 322" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Posted on Mar 12, 2011
FAULT CODE 094-322. WHAT CAUSES IT AND HOW DO I GET RID IF IT?
ERROR CODE 094-322 RAP Second BTR Retract Failure
The error relates to the Second bias transfer roller not retracting. It could be a fault with the roller but i would open the transfer draw and check the connections and seating of everything and try it again. More often than not this clears the error.
Jun 24, 2011 | Xerox DocuColor 12 Color Copier
Display show check printer, error code ##322
the error code ##322 appears when the fixing unit is not working. the heater does not reach the specific temperature. check the resistance of the heater, or a pooor contact . but the best solution is replace by a new fixing unit
Aug 28, 2010 | Canon FAX-L200 Plain Paper Laser
Error code ##322
that code is a fixing heater code, may need to replace fuser heat roller
Mar 16, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
When I send a fax, I get error code 322. I can't receive faxes either.
The error depends on the fax model that you are using. Error 322 on Canon Fax and other machine may significate that the Fuser is not heating (Usually Bad Fuser Module).
A different thing is Comm error 322 on computer, that means that there is no communication, and can be caused by bad phone cable, software problems and hardware problems.
In that case ensure that you are using a fax cable with two poles. If the problem started recently do a system restore to a date before the problem started.
If you get the 322 on display, even when computer is not connected, you usually need to replace the fuser unit.
Regards.
Mar 06, 2010 | Computers & Internet
##322 - error code. Alarm light will not shut
##322 is the fuser unit not warming up!Can be replaced and fixed!
Dec 10, 2009 | Canon Office Equipment & Supplies
It has an error code 322.I took out the drum unit but upon returning it gave me the error code
sc-322 is a code of laser synchronization error.just open the laser unit and clean all the mirrors and lenses carefully with a soft cotton cloth or j cloth.and also clean the polygun motor.this
Dec 07, 2009 | Ricoh Aficio 1013 Copier
Error code 322 cannot find router, after following installation intstructions.
Try manually entering your setup information (login) for your router and see what happens. Don't use the auto configuration wizard..
May 12, 2009 | Linksys Wireless-G Broadband Router
Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
Mar 03, 2009 | Canon LaserClass 7000 Plain Paper Fax
Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Apr 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
Dec 05, 2007 | Office Equipment & Supplies
Computers & Internet Logo
153 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
