I have a leak that seems to becomming from behind my water pump but i dont think its the water pump need a diagram to try to figure whats leaking
  • 5 Answers
SOURCE: 1998 monte carlo coolant
I just did a lower intake reseal on my 98 monte's 3100, it's not tough to do, the biggest part is paying attention to what pushrod came from what position and ensuring they go back to where they came from, not only for wear patterns, but for different lengths on the intake and exhaust push-rods.
I work for a GM dealer in northwest montana, and I can say it's not cheap labor-wise, generally around 6 hours of labor and around 300 in parts...it can add up quick, but when those intakes start leaking oil and coolant, things can go sour quickly...espeically if coolant starts leaking into the engine, not good for bearings.
Dex cool is not the problem with these gaskets leaking, it's common on 3100's, 3400's, 3300's, etc, any motor from that series that has that style of lower intake is prone to the issue, the rubber/plastic/composite will eventually warp, break down, crack, seperate from hot and cold cycles, I've seen it all too many times. Dex cool is the best coolant out there, there's a reason that prestone, peak, zerex can't compete, in fact a few of those blends are blends that are less efficient that Dex that GM decided not to patent. But the Dex patent is due to run out soon to the point everyone can start using dex. One issue with dex is the "gum-up" problem when the mixture is not ideal and the level is left low, but flushing and setting proper mixture (50/50) and level will alleviate this problem.
Posted on Dec 09, 2008
  • 104 Answers
SOURCE: How to remove a 2003 GMC Sierra water pump
I personaly dont see many water pump gaskets leak, but instead there is a weep hole that they leak from when they wear out. they are designed this way. which is common. reason it may leak with ignition off is now the pressure builds up verses being cycled through the engine and doesnt reall have time to squirt out.and it just finds a way out with engine off which would be your weep hole most likely.
Its not hard to fix or replace water pumps on the gas engines. there should be the large A/C and powersteering bracket that can be removed and sometimes if you dont have clearence the alternater bracket. its not very hard. basic tools work just fine. the only thing that may be alittle hard is the fan nut. you will need a large wrench and something to stop the pully from spining while loosening and tightening that nut. should take about 2 hours or so. IIRC13mmm, 15mm bolts, 9/16 bolts and 10mm and 8mm bolts. that all you need.other than the large wrench. pipe wrench will work but you need something to prevent the pulley from movning. thats very important.
Good luck. I hope i answered your question.
Michael
Posted on Apr 29, 2009
  • 340 Answers
SOURCE: Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Posted on Jun 18, 2009
SOURCE: Water leak next to block behind water pump.
i have a 1999 ford explorer v8 5.0 and it is leaking right behind the waterpump. but not from the pump, about 5 inches behind the pump, like by the block, what is it?
Posted on Jan 20, 2010
  • 4 Answers
SOURCE: I have a water leak on my 96 camaro. It has a 3.8
It is your Lower Imtake Manifold gasket (LIM). Late Production Camaros and Firebirds used Dex-Cool coolant which nortoriously caused the LMI to actually disintegrate. The failure of the LIM allows coolant to leak to the exterior of the engine as well as into the interior of the engine eventually getting into your oil. Check your oil for a brown milky color... if you have it immediately drive your car to you favorite repair shop and replace the LIM gasket. The GM 3.1L, 3.4L and 3.8L engines are famous for disintegrated LIM gaskets and a good shop will have replaced 30-50 of these in a year. The LMI is part of the reason the public dissed Pontiac and eventually led to its demise (not to mention bad management at GM). Find a shop familiar with the LIM problem and it shouldn't cost more than $500 to replace (or less). If you have any mechanical skill you can replace it yourself... the gasket kit costs about $35 at NAPA AutoParts and it takes a whole Saturday if it's your first time. I just finished replacing the LMI on my wife's '94 Firebird.
Posted on Mar 23, 2010
Is there a water system diagram available for a honda ballade 150 luxline 1998?
There is definitely no valve there - the only pressure relief valve would be inside the radiator cap. What you see is leakage from a water pump bolt or from the water pump itself. You could try applying a waterproof sealant to that bolt, but it's tricky - allow the engine to cool FULLY, then remove the bolt and hold your finger over the bolthole while a helper applies sealant to the bolt threads. Quickly put the bolt back in the hole so you don't lose very much coolant, tighten the bolt again.
If that doesn't do it, then the leak is really coming from the front seal of the water pump - meaning the water pump needs to be replaced.
Aug 12, 2014 | Cars & Trucks
I have a antifreeze leak on a 2003 ford sports trac
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e4058#hd1-1-1 Hi Donna,here's a link to the water pump diagram,is the mating surface that the gasket goes on clean and not badly scraped up from removing gasket,the pump itself is aluminum and could be warped and not sealing good causing it to leak,maybe you need a new water pump,hose on that side isn't leaking?
Oct 12, 2012 | Ford Vehicle Parts & Accessories
Overheated, not enough to hurt anything. Saw a puddle under the car and couldnt figure where it is coming from. Seems to be near the water pump. For the kicker it is not leaking all the time just here...
Check behind the water pump pulley. If it's wet, the water pump is leaking. Sometimes the water pump seal will leak intermittently until they finally give in the ghost. In the meantime also check all of the small hoses from the area of the pump to make sure it isn't one of them.
Jun 27, 2011 | 2005 Suzuki Forenza
I have a water leak. the hoses all seem good as does the "weep hole" on the water pump. The oil and trans fluid look normal and the car runs fine. The only thing I see is below the alternator...
Not all water pumps leak from the weep hole, if the water pump casket becomes worn then it will leak from behind the water pump. You can also have a leak coming from the thermastat housing. To find out exactly have a pressure test performed on your car.
Feb 28, 2011 | 2002 Chevrolet Impala
Coolant Leak at Engine Oil Pan
CHECK FOR LEAKING WATER PUMP WEEP HOLE OR GASKET.ALSO CHECK WATER PUMP HOSE FOR LEAKS.IF ALL LOOKS GOOD.YOU COULD HAVE PINHOLE LEAKS IN RADIATOR CORE LEAKING ON FRONT OF ENGINE OR INTAKE MANIFOLD GASKET LEAKING COOLANT.
Jun 08, 2010 | 2001 Jeep Grand Cherokee
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
2001 Honda CR 125 motorcycle is leaking coolant from a small hole right behind the water pump. What is the purpose of this small hole? Why is my coolant leaking from there?
The hole that your coolant is leaking from is a vent hole. Its purpose is mainly to give the airspace behind the water pump a place to expand into the atmosphere, and a place for the coolant to escape when the water pump seal goes bad. Every vehicle I can think of, if it has a water pump, its got a vent hole. So, what you are faced with is replacing the water pump with a new one (seals and individual parts are not available for the water pump on your Honda).
Dec 12, 2009 | 2002 Honda CR 125 R
97 dodge avenger-the tube behind water pump is
the dealer should be able to get these. you may have to remove the intake manifold or see what you have to remove in order to do the job. its not something an amateur should try to do. They usually leak because of poor maint, and degraded coolant. If its leaking, more cooling problems are likely on the way.
Jul 22, 2009 | 1997 Dodge Avenger
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
