Question about Canon Office Equipment & Supplies
My canon mx860 keeps displaying "no paper in rear tray". i do not want to use rear tray. how do i switch to front tray?
SOURCE: Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Posted on Jun 13, 2009
davedstone
  • 11 Answers
SOURCE: Paper Jam MX860
Double check as sometimes a small amount of paper will give this error message. If you are sure no paper is in the path/feeder, then unplug your printer from the ac supply for about 10mins (Logic reset) then plug back in and this should have this working again.
Posted on Sep 12, 2009
samadhan_law
  • 54 Answers
SOURCE: canon pixma MP620 paper jam
i think u r roller of the pixma is getting hard so loose it means scroll it by u r hands for one or two times and then try
Posted on Jul 25, 2009
  • 183 Answers
SOURCE: canon mx 860 will not print from rear tray: gets
From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
Posted on Oct 10, 2009
SOURCE: Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Posted on Nov 10, 2010
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
My canon mx860 says to add paper & there is plenty of paper in the tray.
Call 1-800-243-0019 Canon Printer 24/7 find here Canon Printer Customer Service number 24 hour and booming path to get instant technical support for technical problems.
May 09, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Printer notes "Error 6000". It is being used
Take a close look at the printer and the paper tray. The error usually means that the paper output tray is closed (or something is blocking it from opening). Remove the object blocking the paper tray and pull it fully open (including the extension). Then turn off the printer and turn it back on. The error can also occur when a book is being scanned that blocks the paper tray.
Some documentation on the Canon error messages for the MX860 is here: https://www.canon.ie/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX860.aspx?faqtcmuri=tcm:24-644260&page=1&type=faq .
I hope this helps.
Sep 11, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a Canon MX860 wireless printer. There is a paper jam. The paper is all the way to the back of where the paper tray goes and I can't reach it. I do not see anywhere on the back of the printer...
Canon says:
  1. Power off the printer.
  2. Remove paper from the Rear Tray.
  3. Look in the Rear Tray area for an obstruction. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove the foreign material by hand, or with tweezers.
Sep 24, 2010 | Canon Office Equipment & Supplies
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
The feed switch on my Canon Printer MX700 keeps reverting to the rear tray, so I cannot print out anything on standard 8-1/2 x 11 paper.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Cassette error
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
437 people viewed this question
old marine
old marine
