Question about Fujitsu Heating & Cooling
After my husband cleaned the filters the cooling isn't working - its just blowing the air at room temperature the timer light is flashing green what do i need to do to reset it? thanks
  • jshorland Mar 13, 2011
    Yes! thanks so much we now have cool air flowing again - too easy!! Great service
    Jenny
  • 1,940 Answers
If the TIMER indicator lamp flashes when the timer is operating, it indicates that a fault has occurred with the timer setting.
  • Use the TIMER button to select "TIMER RESET." The air conditioner will return to normal operation.
  • To restart the Air Conditioner unit, unplug for 5-10 minutes, and plug it back in. If the TIMER lamp continues to flash, there is an internal fault.
  • To Stop the Air Conditioner During Timer Operation press the START / STOP button.
  • If, after cleaning the dust collection unit, the operation indicator lamp and the timer indicator
    lamp flash during Air Cleaning, please ensure that the unit is not damp and that the intake grille is properly closed.
  • If, after having checked that the unit is fully dry and that the intake grille is closed properly, the indicator lamps continue to flash, the dust collection unit may be damaged. Please consult an authorised dealer to obtain a replacement.
Posted on Mar 12, 2011
Well,same hapen to me with Fujitsu AOU36CLX, but in my case I clean the out site condensor and I made a big mistake...I open the top cover and I use a pressure washer, so you know what? the capacitor control board blow up.Now I can't finder it show a p/n SACT32010F made by Hitachi,If somebody knows were I can buy,please let me know. fredestrad@aol.com
Posted on Jul 07, 2013
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Unit will not heat, change batteries controller cleaned filters etc. Still blowing COLD air
Check the thermostat setting...in the auto machines, with a reversing valve, there is no heating or cooling, generally, in the sensing temperature band of 19 Deg C to 22 Deg C and it only works on blower mode, re-circulating the room air. When the sensing temperature goes below 17 deg C, it works on heating and when the sensing temperature goes above 24 deg C, it works on cooling
Sep 05, 2011 | Heating & Cooling
My portable air conditioner stops blowing cool air after a while and the light is flashing with a sign "lo" Does anyone know what this means?
Flashing lights are generally a sign of something wrong or something needs attention. Try emptying the water canister, cleaning the filters etc.. Not sure what LO means on your model. LO on some wall mounted splits means that the room temperature is below what the remote control can pick up.
Jul 03, 2011 | Heating & Cooling
Cooling issues (low refridgerant?)
Make sure both the evaporator and condensor coils are clean. After the unit has been off for a couple of hours, start it back up and measure the temperature difference between the air entering into the unit (room air temperature) and the air blowing out of the unit and into your room. You should have approx 20 deg......take this measurement after approx 5 minutes of run time. If the temperature difference less than 15, you may very well have a refrigeration problem. If it is approx 20 degrees, then it could be a dirty coil or an electrical problem.......inspect all of your electrical wires and controls for any signs of overheating.....tighten all connections.
I hope you find this to be very helpful in your diagnosis. :-)
Mar 23, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Blows room temperature air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Please remember to leave a rating before you go!
Thank you
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
1,072 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
