Question about Maytag MDE9206 Dryer
When you push the start button,the dryer emits a loud hum,and the drum slowly starts to turn.it wont reach full speed.
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 12, 2011
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
When push the start button you just hear a hum, the drum wont turn, now if you reach inside you can turn it by hand, the belt seems to be intact
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 20, 2010 | Maytag PYE2300AY Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
How do you know if the motor is going bad? Sometimes when I start it the motor will hum for a few seconds and them will start real slow. other times it wont start at all. can I isolate the motor to see if...
Three possibilities: the drum bearings may be worn causing hard turning, the motor bearings may be about worn out allowing the rotor to contact the stator inside the motor, and last, but maybe the most likely, the start capacitor, which is mounted near the motor, may be going bad causing weak starts at first, then no-start/loud humming finally. Take the belt off of the motor pulley and start the dryer--the motor should almost instantly be running full speed. You can test the motor bearings (when motor is OFF) by trying to push/pull the shaft in various directions sideways. Any obvious slop is a sign of worn bearings. Try turning the drum by hand to see if it turns fairly freely. Hope this helps!
Feb 28, 2010 | Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Drum turns hard after holding start button down and has a loud hum
that is a sign of the dryer motor going bad,it will fet to the point where it will not work at all just hum when you push the start button,time for a new dryer it's not worth fixing-mike
Apr 28, 2009 | Kenmore Dryers
Dryers Logo
175 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
