Question about Toshiba TDP-ET20U DLP Projector
Where can I buy a remote control for a toshiba ET20 DVD Projector?
    Genius:
  • 1,739 Answers
Projector will not turn on from standby
Hi, did you ever get an answer to your question? I have an ET20 which, after several months of non-use, has now stopped working. The standby light is on, it makes a startup 'noise' but then does nothing. None of the other buttons are illuminated. Is this similar to your problem?
Dec 29, 2013 | Toshiba TDP-ET10 DLP Projector
The codes I needed are for a URC remote to control a toshiba TLP 560 projector with came with a CT 90106 remote [ remote lost]
0219,0216,0211,0215. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 17, 2013 | Toshiba CT-90157 Remote Control
Remote control for Toshiba 20AF45
Just buy one universal remote control which have set up codes for Toshiba, or an orginal one from the authorised service center for Toshiba.
Mar 27, 2012 | Toshiba 20AF45 20" TV
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
Projector over heats while watching a movie. it just powers down without doing its usuall cool down exercise. maybe its a power issue but the temperature coming out of the projector is very hot.
I would check and make sure that the vent area is clear of dust. The vent being blocked with dust would cause the temperature to rise very fast while the projector is on.
Feb 26, 2011 | Toshiba TDP-ET20 DLP Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
Thin black lines: projector TDP-ET20
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Sep 26, 2009 | Toshiba TDP-ET20 DLP Projector
Lost manual
The manual is available online quite easily. Just google.
As for the audio connection, this is one big drawback of the TDP ET20. it only has digital audio out so you can't connect it directly to headphones or ordinary speakers. You need a home theatre system or an amplifier that accepts digital audio. Or you need to buy a seperate digital to analog audio converter.
Big pain.
Jan 15, 2009 | Toshiba TDP-ET20U DLP Projector
Will not turn on at all
you will probaly needs a new power supply in it. make shure that your getting power from outlet to. Hope this helps
Jan 13, 2009 | Toshiba TDP-ET20U DLP Projector
Toshiba TDP-ET20U DLP Projector Logo
130 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
