Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How to install Mower blade drive belt on 19.5 HP Craftsman 42" Lawn Tractor-Model # 917.270810, without removing mower from tractor.
    Novelist:
  • 144 Answers
Hi donsig245,
What I do is to drop the mower assembly to the ground, then I have enough room to install the drive belt without having to remove the mower assembly. You could put the tractor on blocks to lift it up higher so the mower might go a little lower, but it is the same procedure to install the belt. That is the only way I know to install the belt without removing the mower assembly. I know this is not what you wanted to hear, maybe somebody might have another idea that would help you. Regards and good luck.
Posted on Mar 12, 2011
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Install mower belt
Lift the front of the tractor about 3 feet off the ground& remove the right side rear mower hanger to give you clearance to do the job. Make sure you get the belt on the pulleys and not rubbing a blade brake arm or an idler pulley keeper or the new belt will burn off in about 10 minutes.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
241 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
