Question about GPS
It says please remove sd card and reboot the device
  • 12,061 Answers
OK, this means to remove, from a PC if connected, remove any SD or Memory Cards, that maybe being used, and then to find the little reset button, (usually in little hole at side/rear) and depress it for a few seconds, and the GPS will "Reboot" and restart as usual.
Posted on Mar 12, 2011
My sd port cannot read ma sd card
Remove the SD card, reboot insert the card. Is your Card reader enabled in Device Manager? Have you done any updates? install the Card Reader driver. Toshiba Support : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Jan 17, 2013 | Toshiba C855s5214 15.6 Inch Laptop
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
Upon powering up my screen will only show the message loading os image and will go no further. How do I fix this problem
SYLVANIA SmartBook Operating System Update:
  • Format an SD card 1GB or larger to FAT32
  • Insert formated SD card into your PC
  • Download and save the SYNET_NEW_SHELL_IMAGE.zip (65MB)
  • Unzip the SYNET_NEW_SHELL_IMAGE.zip (65MB) file to the root of an SD card.
  • This should result in the creation of a folder called script in the root directory of the SD card.
  • Insert the SD card into the SmartBook (netbook) device and power on the netbook.
  • The netbook will update its software. Wait for the window ?Upgrade? completed.
  • When completed, remove the SD card and reboot the Smartbook by pressing the device hard power ON/OFF button.
http://www.digitalgadgets.com/mini-netbook.php
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 01, 2011 | Sylvania G-Netbook
I was trying to upgrade the software and it wiped the comp clean can you do a reset
  1. Format an SD card 1GB or larger to FAT32
  2. Insert formated SD card into your PC
  3. Download and save the sylvania_smartbook_OS_update.zip file
  4. Unzip the sylvania_smartbook_OS_update.zip file to the root of an SD card.
  5. This should result in the creation of a folder called 'script' in the root directory of the SD card.
  6. Insert the SD card into the SmartBook (netbook) device and power on the netbook.
  7. The netbook will update its software.
  8. When completed, remove the SD card and reboot the netbook.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Sylvania G-Netbook
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
I forgot my 3 digit passwod
1. Remove the battery and the SIM card and SD card if you have one from the device.
2. Flip the sidekick open; press and hold the letter 'r' on the keypad.
3. While holding the letter 'r', place the battery back in the device. DO NOT INSERT THE SIM CARD YET.
4. The sidekick will restart itself twice. Please make sure not to let the letter 'r' go until it has fully rebooted.
5. Once it has fully rebooted, remove the battery, re-insert the SIM card and battery and power up the device.
6. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factory settings
Mar 14, 2010 | T-Mobile Sidekick II
Vaio won't register micro sd
Have you installed the driver for the SD card reader ? built in vaio ? check within the control panel, devices, sometimes removing the device then rebooting sorts it, press delete on the device within device manager then reboot, check it, should be back and hopefully working
Jun 14, 2009 | SanDisk 2GB microSD Memory Card
How to hard reset the htc 710
to hard reset the htc s 710....................
1) switch off the phone first,
2) again switch it on....and as soon as the green led starts blinking (indication of phone coming to life) immedietly press and hold both the soft keys at a time, and follow the instruction given on u r phone screen. :)
Jul 09, 2008 | HTC S710 Smartphone
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
