How to format from mac to seagate - Computers & Internet
    Scholar:
  • 158 Answers
If you are referring to mac as Mac O.S. and Seagate. Mac is a non-dos operating system and seagate is the manufacturer of the harddrive. If you want to remove the mac o.s. from the seagate harddrive to install windows you will need to run F-Disk > choose to have large disk support > then once in f-disk you will se options, one in particular to remove non-dos partition/s afterwhich once removed you will need to create a new partition and make it active. After this you can then exit the f-disk and upon rebooting the computer install your windows via the installation media
Posted on Mar 12, 2011
Seagate will not work with my mac
If the Seagate has been formatted on a PC in NTFS file format then the MAC cannot read and write to this hard disk.
If you want to exchange data between a PC and a MAC then the hard disk needs to be formatted on a PC in FAT32 file format.
Jan 01, 2013 | Computers & Internet
How to write to a seagate hard drive from a mac
you will need to reformat the seagate drive if it has not been formatted for mac.to do this.
connect your seagate drive to the mac.go to spotlight the magify glass at the top right corner and type in disk utility and select disk utility
in disk utility make sure you select the seagate hard drive and choose erase. at the middle of the screen look for format and choose mac os extended. click erase.
you should now be able to write files to your seagate drive.
also if you would like be able to transfer files to and from a mac or PC then you will need to format the drive as FAT.
Feb 15, 2012 | Seagate 1TB FreeAgent USB 2.0 External...
Can I restore my files from my pc to a mac using my seagate free agent external drive?
Yes you can, but use the FAT32 format, it is the only format that both can read and write to.
Sep 13, 2011 | Seagate Computers & Internet
My mac OS X 10.4.11 won't let me drag and drop into Seagate Expansion 500GB - says it can't be modified!!! Help please.
If the drive is formatted with NTFS (the format used by recent Windows operating systems), then you won't be able to write to that file system.
What you will need to do is reformat the drive to HFS or FAT32.
If you will be moving the drive between a Windows and a Mac, then you'll have to format with FAT32. If you will only be using the drive on your Mac or other Macs, then format the drive with HFS.
NOTE: unless you copy the existing files off of the drive first, you will lose all data on the drive.
To do this, do the following:
  • Copy all existing data off of the Seagate drive to a safe location
  • Unmount the Seagate hard drive
  • go to your Machintosh HD / Applications / Utilities folder and start "Disk Utilities"
  • Select the Seagate drive from the list
  • click on the Erase tab
  • Select the Format. For HFS choose "Mac OS Extended (journaled)" for FAT32 choose "MS-DOS FAT"
  • Type a name for your volume in the Name: field
  • Click the "Erase..." button and allow the Disk Utilities program to format the drive
  • Once the drive is formatted, you will be able to save files to the disk.
Thanks for using FixYa and have a great day
Jan 15, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Hi i need to copy files from my macbook to my seagate hard disk which is in ntfs format.. it says it is write protected... help me...
the ntfs format is windows operating system format...
MAC will not recognize this format...
You need to format your hard disk according to the MAC OsX from your MAC computer...
Dec 13, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
Have a used seagate 300gb, trying to format for mac do i need a disk????
No goto Seagate.com and download Seatools check to see
if they have this utility for Mac if not use their default program
Seatools is for formatting their HDDs . check for OS requirements
Mar 13, 2010 | Seagate Barracuda 7200.8 300 GB Hard Drive
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Im trying to copy from mac to pc using seagate removable hard drive and its not working? When i plug the Seagate into my PC nothing happens
The hard drive volume format is only for MAC. Check the volume format if it is MAC OS Extended or MAC OS Extended (Journaled). If it is, then change it to MS DOS to make it readable and writable to a PC and MAC OS
Jul 08, 2009 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
My Freeagent external hard drive doesn't show up on My Computer
Your Mac would have formatted the Seagate drive as HFS+ (journaled) format. If you have access to a Mac, copy your data off the Seagate to any Mac, then use your PC to reformat the Seagate drive in FAT32 format. Macs recognize FAT32 format, and can store data in it, but can't create the format. The Mac holding your data can store it on the Seagate in the FAT32 format, and you can then copy the files to your PC. Hope this helps.
Feb 25, 2009 | Seagate Free Agent Go Small 12 GB USB...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
