Question about Dryers
My sears kenmore gas dryer stopped heating. model #11078932790 which is 13 years old.... does it need a new burner assembly or do I need a new dryer?
vanni7
  • 163 Answers
SOURCE: GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Posted on Jan 03, 2009
farfield
  • 462 Answers
SOURCE: Is this the right number for my dryer?
Yes the Model Number on most all sears Kenmore products have a 3 didget code a dot then the rest of the model number. The first 3 numbers denote the manufacturer.
Posted on Mar 13, 2009
jmeredith
  • 417 Answers
SOURCE: Kenmore Electric Dryer Model 110.6972110 timer motor NG
hi,
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
jm
Posted on Nov 29, 2009
ftw1952
  • 10319 Answers
SOURCE: Greetings -- My 3 year old Sears Kenmore gas dryer
by the burners gas line which is the small line you will see a tube with a wire going to it. That is the spark ignitor which has gone bad and needs a replacement
Posted on Mar 13, 2010
  • 161 Answers
SOURCE: Kenmore Elite gas dryer, ''NO HEAT''.
fuse is located behind rear panel of machine white w/2 blue wires coming to it
Posted on Apr 16, 2010
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
Kenmore dryer, 417.93042202, just replaced gas coil set, but now we only get high heat, regardless of the heat setting.
Those coils serve to supply the gas to the burner and do not have anything to do with the temp. That is the job of the control thermostat. It mounts on the blower housing. Older models have a bi-metal klixon type control. Typically having 4 wires. 2 small wires which heat up the klixon so that it will shut down faster for knits and perma. 2 bigger wires which go to the gas assembly. Newr models have a thermistor. I would be a replacing the control stat stat. LOL
Sep 13, 2012 | Kenmore Sears Dryers
I HAVE A KENMORE DRYER, MODEL # 110.78652700 AND THE BURNER DOES NOT IGNITE. DRUM TURNS BUT NO IGNITION. ANY IDEAS?
check to see if the ignitor is lighting,, if it is,, then you need the coils replaced, on the burner control,, this link shows where they are http://www.applianceblog.com/mainforums/sears-kenmore/17748-kirkland-gas-dryer-no-heat.html if the ignitor isn't glowing,, replace it
Aug 22, 2011 | Dryers
We have a sears dry model no. 1107481220 and the dryer is not drying the clothes.
Ok, first does the heat come on at all, if not,, make sure the gas if coming on, if it is, you need to check the thermostats, If its not, you need to replace the coils located on the gas valve itself it looks like this http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/694540/0026/110/Model-11074812200/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11074812200&subCompDesc=Burner%20assembly&brandDesc=KENMORE&modelDesc=GAS-DRYER&blt=11 that is the main one, and you have a second one too that should be replaced at the same time, it has 3 terminals, for a diagram of the burner assembly click on this http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11074812200/0582/0151200?searchedModel=1107481220&blt=
Jul 09, 2011 | Kenmore 74892 Gas Dryer
Kenmore Gas Dryer (Model #110.76022990) not heating and timer not working in Knit/Delicate setting. Then timer not working in any setting and still no heat. Talked with a repair man over phone and he said...
There should be a small plastic cover on the bottom left corner of the front panel so you can observe the burner assembly while it is running. Your watching for the burner to ignite after the glow coil heats up. It may work initially but after you leave the dryer run you may notice the glow coil on and when it cuts out the burner won't ignite. If this is in fact what is happening you will most likely need to replace the gas valve coils.
Jan 13, 2011 | Kenmore Dryers
Greetings -- My 3 year old Sears Kenmore gas dryer 600 Series model 776226 will not heat. All else works. No ignition from the burner area. Can you help me identify the problemed parts? I have the unit...
Mar 13, 2010 | Dryers
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
I have a 5 year old Sears Kenmore dryer that won't offer heat
This is an electric heated device?
Do you use fabric softener sheets in your machine? If yes, have you tried cleaning the sensor? Look on the back wall for a sensor. Check with Sears for specific instructions.
Sep 21, 2009 | Dryers
Soot from gas dryer!
have you recently changed from natural gas to liquid propane, or visversa? if so, this could be the problem. especially natural gas to lp.
Oct 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore gas dryer after 5 to 10 min. later no more heat
My Kenmore 80 series (model 11072802100) has the same problem that it fires up first and then stop producing heat after a few minutes. It's also 7 years old. After a while, if I restart it, it will run and do the same thing. I found a thread of discussion on another forum that says that this can be the gas valve coil (solenoids) problem as these coils turn on and off the gas flow to the chamber. I'm going to check out the coils, but don't know where they are located (can't find the manual). If anyone has any idea, please share. Or I'll just tear off the top and back to see where they are.
Any gurus here to help? Thanks.
Oct 10, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
