Question about Compaq Audio Players & Recorders
CANT HEAR SOUND OUT OF SPEAKER SAYS PERIPHERAL IS NOT PLUGGED IN !!!!!!!!
  • Compaq Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Posted on Mar 12, 2011
There is a headphone icon on my net 10 phone and i cant hear any sound
1) Reset the phone.
2)Try again, and see what happen.
3) If not work, you must go to repair shop, the speaker will be faulty.
God bless you
May 09, 2012 | LG 800g TripMinutes Touch Screen tracfone...
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Jul 12, 2009 | Music
CANT HEAR SOUND
Tried double click the speaker icon in System Tray and maxed out the "Wave"? Then increase the Master Volume.
Jun 26, 2009 | ASUS VW192S Monitor
Headset & speaker both are playing at same time
Most probably headphone socket in the laptop is dirty. Spray some WD 40 or replace it.
May 20, 2009 | Logitech 250 Headset
I cant hear no sound on my 6300 even thow i buyed a new speaker an fitted it in it still dont work
Please get sound IC changed from your authorized person to get the best original quality sound.
Apr 23, 2009 | Nokia 6300 Cellular Phone
Speaker problems
Check to see if its plugged into the GREEN jack on the back of you computer?
Hope thid helps. Bud
Jan 07, 2009 | Acer AL1917W LCD Monitor
-mate JAM Pocket PC Problem
Try putting in earphones and check. Sometimes the contact inside the earphone jack jams against each other and then the phone thinks there are earphones plugged in thus bypassing the speaker.
Oct 27, 2007 | i-mate JAM Pocket PC
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
44 people viewed this question
Top Compaq Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
