Question about Xerox WorkCentre Pro 90 Copier
We have a Workcentre Pro 90 with a paper jam -- it keeps saying clear jam in 3E, but we can't find a 3E! Where is it? We don't have a manual. Thanks!
    President:
  • 2,072 Answers
That is to the right of the paper trays, sometimes falls into the inverter.
Can be hard to get to.
Posted on Mar 12, 2011
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
Workcentre Pro 2636 giving error message of: Clear Jam in area 1. we have done this with no luck. Have opened and cleared all areas, even shut the machine down and started back up with no luck. Any...
From past experience this is more often than not caused by a little tiny piece of ripped paper still stuck in the machine somewhere. Turn all rollers and have a really thorough check, especially inbetween the rollers and under any clip down areas on the rollers too..
Jan 27, 2011 | Xerox WorkCentre Pro C2636 Color Copier
What does code J1 mean on a xerox work center pro?
J1 mean any paper jam in paper feed area or sensor displace.lower cassate or multi pass tray.clear jam paper then solve your problem.
Dec 23, 2009 | Xerox WorkCentre M-24 Color Copier
My workcentre Pro 416 shows a jam, i have removed all jams that i could see. However it shows clear jam, and has 19 to dos on the screen, like open door, clean jam, close door, etc.. Is there a major reset...
On this 416 machine, there is one place you cannot see a jam.
Looking at the machine the right side doors need to be opened.
The lower trays feed paper and need to go up the by pass feeder area.
Just lower and behind the by-pass feeder the paper can get stuck, and you cannot see it.
If you try to push a card stock up from the bottom, the paper can be pushed out.
The other area is at the fuser. If the switch is worn it will not drop back into position. The tip of the switch wears and breaks off.
It is rare a sensor goes out on this machine, besides the fuser sensor. Each paper feed head needs to be checked to see if the paper sensors are bad.
Not seeing the machine, call Xerox for service repair if not resolved.
Jul 15, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Promblem with xerox printer
This is solved with if you do a clear all Memory procedure under the Maintenaince settings
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
