Question about GE 24 in. GSD6260JSS Built-in Dishwasher
GE GSD6610GWW Max. Middle arm not turning, glasses are left dirty?
  • 72 Answers
Check to ensure that the arm moves freely. Also, check the mechanism that turns the arm... usually water propelled. The tube carrying the stream of water to the drive arm can be clogged with debris. Clear and try it again.
Posted on Mar 12, 2011
How to start it up
Hold down the middle button on the left arm until the green light on the inside right arm comes on...to pair the glasses to a device,hold down the middle button on the left arm until a solid red light comes on the right arm on inside of the arm if your device asks for a code its 0000 that's all zeros
Jul 05, 2011 | Oakley O Rokr Pro Sunglasses
I have a KitchenAid Dishwasher Model KUDT03FTSS0. I am having a problem with the glasses on the top rack not being fully cleaned. There seems to be an amount of residue left on the glasses. I have...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 25, 2011 | KitchenAid Dishwashers
The middle arm on my dishwasher (ge Profile) is not turning...the top and bottom are working fine
Had same problem with mine. Actually bought all new middle arm assembly but as I was taking it apart to install new pieces, I noticed so much gunk in the middle swinging mechanism that I assumed that must have been the problem.. I really think the newer dishwashing tablets cause this buildup problem. Anyway, put on all new pieces and started the machine. Long story short, it worked great for about a month and then started doing the exact same thing. THE reason why the middle arm sprayer doesn't spin is that the little holes at each end (the ones that sit underneath and look like they should propel the sprayer arm ) get clogged. I bought some pipe cleaners, bent to an angle where I could come in from the top and pull out through the propellor hole and voila` the sprayer is swinging beautifully again.. I guess the only question I still have is why this started happening three to four years after I purchased the machine. Something somewheres else must not be doing its job.
May 18, 2010 | Dishwashers
Water not getting to upper wash arm / glasses on top rack are dirty after the cycle - I do not know how to take out top slide basket to check water flow in tube at rear of machine-
remove the roller rack plastic end caps this will let you remove the upper rack,then you can replace the whole wash conduit from the bottom sump all the way to the top,also if theres a middle(center arm) this has a horn on it that is to seal when the rack and door are in and closed,but after while the water wears out the plastic o-ring and they leak and you lose water pressure to the top wash arm
Apr 01, 2010 | Dishwashers
GE GLD5800L Middle Spray Arm is Not Spinning
The middle arm may be missing an O-ring at the back of the dishwasher.
Mar 23, 2009 | GE GLD5800L Dishwasher
GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Nov 05, 2008 | Kitchen Ranges
GE Triton arms don't spin
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Sep 06, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE dishwasher Quiet Pro 3 middle washing arm
Try unscrewing it from the bottom, remove it and give it a clean. If it is full of food it will not turn.
Check the funnel on top of the basket is free of food too.
Jun 10, 2008 | Dishwashers
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
GE 24 in. GSD6260JSS Built-in Dishwasher Logo
193 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
