Question about Samsung Bn59-01041a Remote Control
My samsung led remote control has just stopped working and i can't get it to work again. I've changed the batteries and i cannot find the reset button. I've unplugged the power from the wall and still no luck. plz help
    New Friend:
Where is the reset button in the remote showing the figure? model UA32D4020N (LED TV)
Posted on Jun 22, 2013
    Novelist:
  • 188 Answers
There is a way to check whether the problem is with your remote or with the infrared sensor in your TV set.
If you have a digital camera (can also be your cell phone camera), it can be used as a kind of a "remote control tester" - although we cannot see the infrared bean emitted from the remotes, the CCD sensor inside the camera can!
If you aim your camera to the remote's extremity (the one that is pointed towards the TV set when you want to change a channel), as if you were going to take a picture of it and press a button in the remote control, you will see the remote's infrared LED blinking.
If you can see that, your remote is operating normally and maybe the sensor in the TV is blocked by an object that is in front of it, by a sticker someone glued in the TV's frame or it just got damaged by a power surge.
If you cannot see it blinking, your remote might be damaged and may need to be replaced.
Hope this info can help you!
Posted on Mar 12, 2011
  • 11,361 Answers
We need to find out first if the remote is putting out the IR signals or not, or the problem is in the TV IR receiver module.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
EBAY. AMAZON
Testimonial: "thx "
  • 1 more comment
  • valid93 Mar 12, 2011
    I tried that and unfortunately there was no flashing light on the camera.
  • Bud Martin
    Bud Martin Mar 12, 2011
    You can get orignal from EBAY or from AMAZON.
  • Bud Martin
    AMAZON:http://www.amazon.com/s/ref=nb_sb_noss?u...
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Logik L32LCD11 remote not working!
use this simple test see the video.the led coming with the r.control must be light to the digital camera. If the LED is not lighting. Open the remote control, and clean, replace battery, and resolder any cold solder in the r. control. clean the contacts battery.
May 22, 2013 | Televison & Video
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
My remote control (BN59 - 01014A) work only on short distance (1 - 1,5 m). I have a TV Samsung Led UE26C4000. I have changed batteries several times, but no results. Please help ! Thanks
Take the tv remote aparts,there is a screw in the battery compartment.I know this because i have a tv this model too.Take some Q tips soak it with some rubbing alchahols and clean the remote PCB board and wait like about 20 mins for it to dries.Put it back together again and with a new set of batteries.And take some cottons balls soak it with some rubbing alchahols and clean the tv set infer red light sensor on the tv set it self too by the tv LED power light indicaton.This solution should improve ur infer red senor reading like( 2-3 more m).
Jul 14, 2011 | Samsung Bn59-01041a Remote Control
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changing a battery on a Cobra 7777 remote control
The battery in the 7777 remote is a CR2032. If upon changing the battery the remote fails to work then you should stand next to the car and hold down both remote buttons for around 10 seconds to reactivate it. The remotes LED will flicker rapidly during this process. Keep holding both buttons until the LED stops flickering then release both buttons. The LED should now be on constant, press the larger of the two buttons and the remote should now be re-synced.
Note: This procedure is not to program the remote to the alarm, but to re-synchronise it.
Aug 20, 2008 | 1999 Mazda 626
Samsung Bn59-01041a Remote Control Logo
1,666 people viewed this question
Jerry Greenberg
Jerry Greenberg
