Question about Canon PIXMA MP240 All-In-One InkJet Printer
After refilling the canon pg-510 ink for the first time it worked well except not showing the correct ink level. When refilled the second time it is giving an error message E and some number. I am informed by some that the printer heads are made to wear off fast allowing only may be one refill; some others say that they now inscript a date on cartridge and the original cartridge and refill will work up to the date and then stop and customers get the message "incompatible cartridge installed". Kindly enlighten me on the above two observations by customers. thanks
    Novelist:
  • 168 Answers
Almost all printers nowadays have a special integrated circuit inside the cartridges that decreases a counter each time they are used and that is how they know the ink is empty. They also DO NOT reset when you refill the cartridge - this is a way to force you to buy brand new ones...
There are ways to reset the printers after installing refilled cartridges - some need special electronic devices to do it, others only need to push some buttons in a specific order. Please, check these four links and tell us if they helped you solve this problem:
http://resetcanon.com/reset-canon-mp240-pixma-inkjet-all-in-one-printer/
http://www.youtube.com/watch?v=MoGKbr5Y5yI
http://www.youtube.com/watch?v=7lQFl6KgexQ&feature=related
Hope this may help you!
Posted on Mar 12, 2011
After refiling the cartridge,printer is not recharging, Error-E-2,7 coming & alarm light also blinking
I don't recycle cartridges but one time. Most of the time they won't work if refilled more.
Apr 02, 2014 | Canon PIXMA Office Equipment & Supplies
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
Ink refill not detected
you must reset the cartridges on mx300
check here the ways
http://inkfilling.net/instructions-on-how-to-refill-canon-pg-37-pg-40-pg-50.html
Jul 25, 2010 | Canon PIXMA MX300 All-in-One Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Cannot send and receive fax after refilling PG-40
I own a Cartridge World ink refilling store and I think that the fax not printing is Canon's new approach to kick out refills from their all in one machines. We cannot reset the ink level indicators on these cartridges and if people can no longer print faxes if their ink says it's low, then they can never use refills if they want to use their fax machine. I think it is also a way for Canon to make more money on their ink sales by making consumers buy new ink before theirs runs out. As far as I know there is no way to fix this problem.
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I refill the cartridge pg 510 from a canon mp240 and i don-t know
You can't reset the counter of any Canon Pixma cartridges.You should be to turn off the function on printer for showing the ink level.In most printers this happen with press and hold for 5 seconds the resume button.
Sep 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Do I need to mix 2ml of each colour in siringe and mix
HI,
Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
thank you,
vijay (vote for me)
Sep 24, 2009 | Canon Office Equipment & Supplies
How do I insert the refill ink cartridge?
according to all information i can find you have got the correct cartridges
nip to canon.com and download the user guide that shows you how yo install your cartriges
Regards AL "alstech"
May 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
1,545 people viewed this question
old marine
old marine
