Question about Frigidaire FDB1502RGC Built-in Dishwasher
Hi There, I have a frigidaire FDB1502RGCO dishwasher and I have power and water going to the macine however when I turn it on it will not start its cycle. Washing light is lit and all functions are lit up as normal on the front panel however the cycle does not start. Is there a simple fix or reset for this machine or will I need to call technical support to have a technician come to look at it? Please let me know. Thank you
5 Suggested Answers
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
SOURCE: frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Posted on Feb 21, 2010
  • 1531 Answers
SOURCE: My Frigidaire Dishwasher FDB1050RES2 gets
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Posted on Dec 29, 2010
Dishwasher started to fill with water, and started to cycle the water, but then suddenly shut down and wouldn't start back up. The lights wouldn't go on at all. Not fuse or power problem.
Hello Jeremiah, thank you for your post!
I understand that your Frigidaire dishwasher started a cycle and then shut down. I would suggest performing a reset and you can do that by disconnecting the power cord for at least ten minutes. If you continue to experience issues you may need to replace the control panel or wiring harness. I would recommend having a professional technician out to your home for proper diagnosis and repair. This will help prevent you from any unnecessary part purchases. -Matt
Jan 08, 2016 | Frigidaire FFBD2406NS Built In Dishwashers
Dishwasher reset button
Hi friend, I appreciate your post!
I understand you are trying to locate a reset button on your dishwasher FDB1502RGC0. Generally dishwashers do not have a reset button on them but in order to reset your appliance as a whole. You would disconnect power to it by unplugging it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this helps. -Matt
Jul 23, 2014 | Frigidaire Dishwashers
Macine won[t start
HI,
Does the unit fill with water, or fail to start? If fail to do anything, I would suggest to check power supply and/or door switch to unit.
I hope this helps
Aug 15, 2011 | Viking DFUD042 Built-in Dishwasher
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
My dishwasher won't drain. I have tried to start it and there is power, but nothing happens.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 19, 2010 | Frigidaire PLDB998A Built-in Dishwasher
Most common problem is a burnt out water valve, which would need to be replaced. When you turn the dishwasher on, does the motor run after a few minutes? If not, it's possible that the latch is faulty. It can fail, so the dishwasher thinks the door is open, and nothing will work
Apr 07, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Dishwasher Not Getting Water
The water inlet valve could be faulty or possible some obstruction in it.
Aug 12, 2017 | Frigidaire Dishwashers
No power to dishwasher
depends on the sequence. many, but not all, dishwashers start with drain to get rid of the slops. if yours starts with fill, then no water supply will prevent progress.(you should be able to hear a low hum which is the valve energised) check also that the door is closing properly and latching. better to use cold water fill not hot
May 09, 2007 | Frigidaire GPDB698SSBK Dishwasher
Frigidaire FDB1502RGC Built-in Dishwasher Logo
93 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
