Question about LG 37LH30 37 in. LCD HDTV
Tv comes on then after a wile the picture goes off then comes back on ?
  • 11,361 Answers
It can be power supply due to bad caps, but we need to find out first if the backlights are on but no pictures, or no backlights at all.
Service manual: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=37LH30&kategoria=tv&kat2=all
Please try this when the pictures go out:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find
Posted on Mar 12, 2011
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Knoking sound wile driveing it comes and goes
is it more from the front or back of the car ?? over bumps ?? while acelerating or braking ??
on the top of the front struts there's a rubber bushing called the "upper strut mount" this is a commonly replaced item. Also the sway bar bushings are frequently replaced. or, it could be something totally different..... gremlins ??
Dec 24, 2009 | 1999 Volkswagen Cabrio
Picture goes out
Has the lamp ever been replaced on this TV? If not it would be the first suspect. The next time the picture goes out look for light coming from the back of the TV where the lamp is. If you see no light then replace the lamp. Please take a few moments to rate my answer. Thank you...
Nov 17, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
My 52 inch rear projecter rca tv model number r52wh74 picture goes black after a little wile and dont come back for awile staying off longer and longer all the time. but there is sound.
It seems that you have either a defective lamp or ballast, i recommend that you replace the lamp first, if it doesn't work it means that it's most probable that your ballast doesn't have enought voltage to keep up with your lamp. I recommend you get a Philips lamp since it's going to give you a brighter image and also it has a longer life spand 6-8 thousand hours, on the other hand, the generic lamps last 3-6 thousand hours and the image is not that bright, so if you're looking for quality get the Philips.
Jun 29, 2009 | RCA Televison & Video
TV Picture
try unpluging the power and pluging it back in.
Dec 11, 2007 | Toshiba 43A10 43" Rear Projection...
Open Questions:
See all LG 37LH30 37 in. LCD HDTV Questions
LG 37LH30 37 in. LCD HDTV Logo
166 people viewed this question
Computer Repairing
Computer Repairing
