Question about Gateway GT5040 PC Desktop
Monitor is not powering up - Gateway GT5040 PC Desktop
  • 384 Answers
Hello there and Welcome to FixYa!
The first thing that you should check is the power cable's connectivity from the back of the monitor, all the way to the plug. It would be better if you have another known good working power cable that you can try so that the problem can be fully determined.
In the event that, after trying another known good power cable, and the situation did not change, then I strongly recommend to take this monitor to Gateway's authorized service center for it to be repaired. I have embedded their consumer support site below if you wish to acquire more information about how to reach their phone support :
Gateway Support
I certainly hope that this could help you, and Thanks for using FixYa.
Posted on Mar 12, 2011
  • Gateway Master
  • 6,771 Answers
If the monitor won't power up, you have a power supply problem. The general cause is bad capacitors that sometimes bulge at the top indicating it is open, to attempt a repair you will need somebody who is handy with a soldering iron to replace the parts, or a service centre, where it will be costly.
Moniter output not connect
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 20, 2014 | Computers & Internet
Hcm 582 monitor not display show
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 23, 2014 | Acer AC713 17" CRT Monitor
Monitor is slow coming on then when on website clicking out of second tab flashes black
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
Monitor light up then shut down itself
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
Bought a powered monitor as it said to do in the owner's manual, even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked...
You haven't mentioned what model and manufacturer the mixer is. I will have to guess and say that the monitor out on the board isn't providing signal to the powered monitor or the monitor out on your board is powered and is now damaged by plugging a powered monitor into it. Carefully reread your manual and determine if the monitor out on your mixer is powered or line level. Reread also and make sure that the signal you are monitoring is assigned to monitor out, levelled correctly etc. If you find that the monitor out is passive (line level) try hooking it up to an external power amp and speaker. A guitar amp will do for testing purposes. Start with a low input volume on the amp. Also make sure that if it is passive to use a shielded cable from monitor out to input. If your board has powered monitor outs you can use a speaker cable from monitor out to speaker input (non powered monitor speaker).
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Princeton VL173 scrren blank
Sounds like the monitor took a power surge. Monitor is probably bad but try hooking up the power to the monitor on a different power outlet and see if it turns on, if not then the monitor is bad and would need to be replaced.
May 04, 2009 | Princeton Digital VL173 Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
No power to monitor
if no power of monitor. firstly Check Power Code .Power Code Is Ok Then Chek Monitor Circuit . power section . firestly Check Fuse On Pcb And Check Power Section Component Mosfet And Diode,
Dec 28, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Gateway GT5040 PC Desktop Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
