Question about Canon Rebel XT / EOS 350D Digital Camera
I having canon eos after i remove the memory card it says error cf or it says busy please help me
  • 62 Answers
Hello
The issues you are running into are indicative of two possible issues.
First, the memory card may simply be bad. But before you purchase or try another memory card, you need to look for the second possible issue. The second issue, which is typcially more common, is that inside the card slot on the camera, there are pins, it is possible that one or more of these pins has become bent or damaged. If you look inside you can usually see a pin or pins out of alignment or bent over. If that is the case, the camera will need to go in for service.
Posted on Mar 12, 2011
Error message ERR CF on my Canon EOS Rebel XT
hi, remove the card , peek inside the memory card slot , check if any of the pins are bent , there lies the problem , if everything is ok , then change the memory card or format the card , use a low capacity card, some card may be incompatible , hope this helps
Jun 06, 2016 | Canon Cameras
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Get Err CF in view finder and cannot take pictures
did you try removing the memory card and making sure its not locked?
Mar 18, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
I have an EOS Canon 400D digital SLR and my husband has bought me a Sony photo printer DDP-FP75 . I had wanted to be able to insert the memory card but it doesn't seem compatible. Can I print using the...
The two are not immediately compatible. The Canon EOS 400D uses a Compact Flash card. The Sony Photo Printer you have accepts SD and Memory Stick cards. Unfortunately, the CF card and SD card are very different.
The easiest solution I can think of would be for you to get an inexpensive card reader (make sure it accepts Compact Flash cards), attach it to your PC and then use it to read the CF card from your Canon EOS -- and print to your Sony printer.
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 24, 2008 | Canon Cameras
CF Card is not being read, Canon Digital 350D EOS Problem
It does not sound good. You might want to get a flashlight or similar and look into the memory card slot to check the connector pins in the camera. They may be bent or damaged.
Jul 27, 2008 | Canon Digital Rebel XT / EOS 350D Body...
Problem with CF Card
Err99 is the catchall error code for Canon cameras for when a system error occurs that doesn't fall into any of the other error categories.
Since this was immediately preceded by a memory card error, I would look down into the memory card compartment to see if any of the pins have been bent or broken.
Also, I would take the lens off the body, and remove the memory card and power the camera on. If the Err99 goes away, the issue could lie with either the lens or the memory card.
Oct 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
285 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
