Question about Philips Gemini CDM-500
How to connect the gemini to the computer - Philips Gemini CDM-500
    Brigadier General:
  • 8,546 Answers
Easy.
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Posted on Mar 12, 2011
How i can connect a Gemini cdm-3610 to a laptopand which cabes i can use
It depends on what connections the laptop has. Most have an audio in socket. So you can use that. All you need is to find a audio out on the deck. I looked at an illustration and it has an headphone socket. So you could use that. Just keep the volume control low.
Sep 20, 2016 | Gemini Audio Players & Recorders
What inputs do I use to connect my laptop to the gemini cdm 3700g?
if it's to record the Audio you need some kind of interface analog(RCA ) to usb like the behringer UCA 202 Now if it's to watch or to try to record Audio and Video you need to look at a video capture type of interface composite audio video to interface like the SIIG USB 2.0 Video Capture Device just make sure its compatible with your OS. Now if you try to use it as a Midi controller with program like Serato , Virtual dj ... you are out of luck this system is not compatible .
Good luck.
Jul 05, 2014 | Gemini DJ Gemini CDM-3700G Dual CD Karaoke...
I dont know how to set up a mixer Gemini 3610 to my laptop and my powered speaker i want to know what cables i need
There are several possible solutions for this. The cheapest and easiest is to do the following:
Solution 1:
1. Get an RCA stereo plug to 3.5 mm plug. This will go from your mixer to your computer. This will not be the highest quality, but will work.
2. Get an XLR cable of the length you need. I would guess a standard one with a male connection on one end and a female on the other. Connect this to your powered speaker. Also, this is a guess as you didn't include the type of powered speaker, so I can't tell you for sure which cable to use.
Solution 2:
1. An alternate idea for better sound quality would be to run a D/A converter similar to this one: http://www.sweetwater.com/store/detail/USBMix/It would give you a much higher sound quality for everything. You would run from your Gemini to this. From this device, you would run a USB cable to your computer, and a 1/4" cable to your powered speaker.
Jul 19, 2012 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
Problem with the Gemini Sound Products Gemini CTRL-SIX USB/MIDI DJ Controller and Audio Interface It wont be detected by the computer's usb on WIndows 7
In the control panel, sounds and devices, check that the device is in each list under audio, voice, and hardware tabs and that your device is the default device. If NOT in the list, the CORRECT drivers are NOT installed or not properly installed.
Jul 23, 2011 | Gemini Sound Products Gemini CTRL-SIX...
Need to replace wireless antenna connection on Gemini RM700. Can't find replacement parts.
Did you ty to contact gemini? If they wont sell you one. We here at Pro Line Music are gemini dealers and I will try to order it for you. 2157368055
Jul 15, 2011 | Gemini Sound Products UF-1064M Microphone
How can i connect my Gemini Turntable which has a ground cable connection to a device that does not have a ground cable connection?
Hi, slip the ground cable in the side of the rca connection to the device without earth point.It makes no difference if it goes in the left or right jacks. styluscity@gmail.com
Sep 06, 2010 | Gemini XL-500 Turntable
How do I connect a reciever to Gemini pmx-2500
look for pre out on your gemini hook up phono cables to these then to any input on your reciever,eg cd, switch reciever to cd turn up and away you go
Jun 20, 2008 | Gemini Audio Players & Recorders
Got a gemini xl500 turntable - sound output problem
OK found the solution - need to connect to preamp before my comp.
Feb 29, 2008 | Gemini XL-500 Turntable
Philips Gemini  CDM-500 Logo
474 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
