Question about Brother Office Equipment & Supplies
Fax 2850 How do I program settings for fax ability line use
Brother NZ Help Desk provided the answer.
Menu Set 2-0-2 Faxability arrow up to turn ON Menu Set
Call Waiting set to OFF Menu Set Will show accepted Press Stop
All so simple but the Manual doesn't cover it.
Thanks FixYa fo ryour follow up.
Norwester
Posted on Aug 01, 2008
Hp 2140 printer
You can't send a fax to your computer.
Sep 23, 2013 | Computers & Internet
Does Windows 7 have the ability to send and
Well Yes, if you have a Modem, You can connect a Modem & then one can get software that you can use as a Fax machine. Also I believe there is a Built In Fax software too. However I recommend a third party setup. There are lots of really good FREEWARE Fax programs. Ensure they work with Win 7.
Feb 05, 2010 | Office Equipment & Supplies
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Brother Fax 2850 no dial tone
who changed out the main pcb board and why, may be one of the connectors was left of , there is a connector comming from the phone board called the ncu board. go over your connections, or if a service center did the replacement it should have been checked out before you got it back, good luck
Dec 25, 2008 | Brother IntelliFax-2820 Laser Fax
Faxing
Did you do the right settings?
Please read manual chap. fax how to set the machine to work for fax abillity for your telephone line. Manual can be downloaded at brother homepage in case you dont have it.
Nov 12, 2007 | Brother MFC 210C All-In-One InkJet Printer
FO 2850 - Power Outage Aftermath
Unplug the machine for 4 hours & then plug back in. If you get the same symptoms, it will be cheaper to replace with a new one. Power supply is probably blown.
Jul 01, 2007 | Sharp FO 2950 Plain Paper Laser Fax
151 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
