Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
My refrigerator is beeping and shows a high temp red light. the temp in the fridge is high. i did try to set a lower temp but it shows EF for fridge and 59 (?) for freezer
the dr
  • 447 Answers
SOURCE: Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Posted on Dec 01, 2007
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
jmgldsmth
  • 1869 Answers
SOURCE: FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Posted on Jul 19, 2010
SOURCE: My refrigerator is beeping and has high
your coils down at the bottom may be dirty & full of dust vacum it out. if the there is ice forming in the freezer it needs to be defrosted.
Posted on Oct 28, 2010
SOURCE: Electrolux EW26SS65GS0 Refrigerator. Temps going
Same problem for past month, tried replacing motherboard and today still showing Red High and adjusting....$500 so far and three service calls...what to do...food thrown out and good thing my garage is cool to store some stuff.....
Posted on Dec 22, 2010
GE Profile Refrigerator, Red Triangle on Display
Usually it means your temps are too high.. If you don't notice any cooling issues it could be just a glitch. Try unplugging your fridge for 15 minutes to reboot it..
Jul 31, 2017 | GE Refrigerators
My F&P fridge was beeping whenever I opened it and temperature gauge at top back kept turning red. It seems to be ok now but what would be the problem?
the temp setting inside the fridge is too close to minimum temp for the sensor
if the door seals are not effective and you open the door it sounds
try turning the fridge setting to 4 or 3 to see if that fixes the fault at 1 it should take a few minutes to make a sound
call a technician if the adjustments do not work
Mar 25, 2017 | Refrigerators
My dd lg refrigerator model GGL-478YSX4/2011 BEEPS EVEN WHEN DOORS PROPERLY CLOSED
Its telling u that the refrigerator setting should be lowered or raised. I keep the freezer setting on the highlighted setting and depending on the weather your refrigerator will beep when the setting is either to high or to low. If its hot and humid outside it probably raise one notch and if the outside temp has cooled then lower one notch. Just have to experiment. Good luck
Jun 12, 2015 | LG Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 14, 2015 | Refrigerators
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Our fridge is making a beeping sound every 2 to 3 minutes. how do we get it to stop????? door seems to be tightly closed. just installed a new filter. freezer feels cold but the gage says its only 39*......
those have a high temp warning,, anytime the freezer or fridge goes above a set temp it will beep,,, make sure all or the doors are shutting good and the gasket is sealing,, if they are try to find any cold air coming out,, if all is good,, you need to get a service tech because it could be a bad fan, or a bad sensor
Jan 24, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
382 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
