Question about Health & Beauty
It is taking a charge but won't turn on it seems to be in slow motion and when you take it off the charger it wont turn on at all
  • 31 Answers
Sorry... but your battery internal to your shaver is bad. Probably cheaper to get a new shaver unless your shaver is under a factory warranty.
Posted on Mar 12, 2011
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My ground force razor drifter drive slow with a full charge it won't go fast
Well most likely, your batteries are weak. When the charger shuts off, the batteries have stopped taking charge, but they're not necessarily at full strength, especially if they've been sitting for a while without being charged. Connect the wires from the power switch together and try again. If it works replace the switch. If not, turn the motor shaft both ways. If it makes clunking noises, it's cooked. Otherwise you probably need batteries. Ive never seen a throttle or controller cause slow operation. And also always keep your tires pumped up.
Sep 29, 2013 | Toys
Kawasaki vn 800 battery won't charge itself
MAYBE IT IS JUST THE BATTERY... TAKE IT BACK AND GET A NEW ONE IF PROBLEM COMES BACK I WOULD TAKE THE BIKE IN FOR A CHECK UP DIAGNOSTIC.
May 03, 2013 | kawasaki VN 800 Vulcan Classic Motorcycles
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
Scooter won't take a charge
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
Jun 26, 2012 | Pride Sonic 3 Wheel Portable Scooter
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
Will the light turn green on the ht1000 charger when the battery is charged? how long does it take?
It depends on the type of charger, a rapid-charger would charge a battery in one hour or less and the green light would come on when battery fully charged. A slow charger will take up to 16 hours to charge a battery and has red light only.
Nov 28, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Problem with extended battery
LED indicator for your laptop model
Steady Blue = Battery charged and AC adapter plugged in
Amber = Battery charging and AC adapter plugged in
Slow Amber Flash = <10% battery life
Fast amber flash = 3% remaining TPC will automatically go into hibernate
Slow flashing amber Adapter plugged in = Overheat condition
Do you have a multimeter to test the battery that you are using? check the output current of the battery.
May 29, 2009 | Motion Computing MOTION LE1600 Notebook
Battery shows 24.8 volts no power
Yes, your batteries are trashed. You need to replace them. Or take them off the chair and put them on a car charger,slow charge. They need to be up over 24VDC. If they fall under 24VDC the charger won`t recognize them and won`t charge.
Mar 30, 2009 | Golden Technologies Buzz Around 3 Wheel...
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
