Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Makes a noise when in the spin cycle. Almost like coins in the barrel only there are no coins in the barrel. Or sounds like it is trying to change gears and grinds.
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
Based on what you've described, sounds like a worn tub bearing unfortunately.
To check it, remove the agitator assembly inside the tub, once it's off. take the tub assembly and move it side to side to inspect for "play" in the bearing. This will explain the bad sounds and the grinding...I bet it doesn't spin the items out very well either due to too much vibration sensed to maximize spin.
Let me know what you find and I'll try to help you move forward from here. I can provide more detail with pictures if necessary.
Regards,
Macmarkus :)
Posted on Mar 12, 2011
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
Makes Noise When Draining on Spin
could be coin in pump..Check this
Apr 08, 2010 | LG WM2487H Front Load Washer
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Tub gets off balance and makes noise while washing.
It probably does this because you have overloaded the machine with towels or bedding try putting less in...
Jan 03, 2009 | Washing Machines
Noise at the end of spin cycle
possible bearing going out in your barrel.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Calypso Washing Machine
There are two places a coin could be that will cause a noise. Either in the basket under the nutator or in the pump. If you hear the noise after the basket stops from the spin, look under the nutator, if you hear it during the cycle, check the pump. If you only hear the noise during the agitation, not the spin cycle, you may have a u-joint going out.
Oct 02, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
259 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
