Question about Canon Image Runner 3320I Copier
How do I change the paper size of the paper source in canon image runner 5570
    President:
  • Canon Master
  • 1,447 Answers
Please follow your copier user manual. How to make a copy.If you hav no manual you can download this web side www. canon support.com
Posted on Nov 04, 2009
  • Sazeed Computer
    Sazeed Computer Nov 22, 2009
    press program manu key paper size left and right arow key see display paper size press ok
  • 31 Answers
Fine all you have to do is you just have to slide paper guides according to type of paper.Usually sliders have green knobs.paper comes in various sizesA5,A4,A3,etc so slide those paper guides acordingly ensuring that the touch paper edges.
Posted on Aug 22, 2009
  • 149 Answers
Just enter the paper stock that you want to use and adjust the guides. The machine should pick up the size if it's in universal cassettes. If it's the bypass, you select 'paper select' then select the bypass and choose the size that you want.
Posted on Jul 05, 2009
In canon IR3300 paper doesnot recognize at all and says load paper every time
on ur PC right click on your image runner go to printer proprieties go to preferences go to default paper size and choose your required size.
Mar 22, 2016 | Canon imageRUNNER 3300 All-In-One Laser...
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
For some reason our Canon Image Runner 2270 started printing in landscape versus portrait. We did not touch the machine and the printer setup shows portrait - I assume I have to change something on the...
Check your paper size/orientation dial on the paper tray you are using. I believe this machine uses this dial to tell the machine what paper size and orientation is loaded. Make sure the dial matches the size and direction.
Aug 20, 2010 | Canon imageRUNNER 2200
Canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Apr 09, 2009 | Canon imageRUNNER 5570 Copier
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
How do I delete an email address from an Image Runner 5570?
push additiona functions button then touch the regieter adress key ( right column last key) select option porbably one touch then select the adress you want to delete
Dec 03, 2008 | Canon Image Runner 3320I Copier
ImageRunner 5570
hello John,
Glad to help. Your copier has 2 seperate sensing devices built into the machine that allows it to automatically recognize the paper size for trays 3 and 4. There is one unit consisting of 2 photo-interruptors that determine the length of of the settings of the paper tray,and a potentiometer that allows the copier to determine the width of the setting of the paper tray. The copier recognizes the paper tray settings automatically as you change them for trays 3 and 4. So there is really nothing required from you other than moving the side guides and the end guide to suite the paper size you wish to insert. The side guides are built into the paper tray and they move in tandem so when you squeeze the blue (I call it a clothes pin since it looks like one) release lever which allows you to change the paper width as you need. To the left of the tray there is a blue square block that is re-positioned as you choose to change paper sizes. This "end fence" should **** against the paper for support and there are markings at the base/bottom if the tray that indicate the proper postion it should be depending on the paper size you need to insert. I believe this pretty much covers it ! :-) Let me know if you need further help and have a great copying experience!!!!! LOL
Jul 31, 2008 | Canon Image Runner 3320I Copier
Pages printing all black
Symptoms of many things, most likely is corona wire in Primary Corona assy snapped and earthing the drum.
Jul 01, 2008 | Canon imageRUNNER 5570 Copier
176 people viewed this question
old marine
old marine
