Question about Panasonic PT-47X54 47" Rear Projection HDTV-Ready Television
Panasonic PT-47X54 The overall vertical size appears too large. The top and bottom banners are cut off, convergence works OK. is there a vertical size adjustment?
  • 2,071 Answers
This is the vertical problem,it is a bad capacitor you must replaced all electrolytic capacitor in vertical section and resolder all associated parts there,so it works better again.
Hope it will helps you;
Regards,
VOTIT
Posted on Oct 10, 2008
My tv has a arching green tint towards the bottom of the screen that also gives off a double image. I have a Panasonic hdtv 47 in screen model no: PT-47wx54j
Convergence problems. If they can't be fixed from the setting on the menu then the convergence board's IC's are faulty and must be replaced. This is a job for someone who has some electronics experience.
Aug 09, 2010 | Panasonic PT-47X54 47" Rear Projection...
My panasonic PT-47wxc43g projection tv has developed shrinkage in the middle of the screen on both the top and bottom. The picture has an hourglass on its side appearance. The picture is now also too large...
This could be a problem in the convergence board which will cost of repair would range 400.00 or so.
You can get the convergence repair kit at the following link which contains the parts and step by step detailed instructions.
http://www.tvrepairkits.net/panasonic_repair_kits
Thanks
Kevin
Jun 29, 2009 | Televison & Video
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
My HDTV seems to be very Low Def - Panasonic Projection PT47WX54J
Ur convergence it dead.Must replaced the 2 convergence ICS.Know how to solders?Tries Tv repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The Shop will cost U $300 parts and labors.
Jan 27, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Hi, we just moved the tv from one room to another and now the images are just greens and blues. We lost the colors! What can i do?
Sounds like you have bad solder connections at your convergence ic's.These are large amplifier ic's mounted on large heat sinks.These ic's run very hot and can cause faulty connections at the solder joints.Try resoldering ,if this doesn't fix it you will need to replace them and any surrounding resistors that have opened.
Nov 04, 2009 | Panasonic PT-47X54 47" Rear Projection...
Convergence On Panasonic PT-47WX54j
Did you do a repair on the convergence circuit? If so it would be ok to do an adjustment in the service menue. But if you have a problem in the conergence circuit and you dont repair it first, making adjustments in the service menue can do damage to the DCU and cause you major problem in the future. If you have already repaired the convergence circuit then let me know and i will get you the codes.
Tim nolan
experttv@comcast.net
Sep 24, 2008 | Panasonic PT-47X54 47" Rear Projection...
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Can't converge the whole screen at once
A surround sound receiver wouldn't cause issues itself but the possibility that speakers could cause issues is there. Speakers usually are an issue with direct view CRT televicions more than CRT projections. Don't move any physical adjustments on the CRT's unless you understand what each magnet is accomplishing on it. It is a electrical alignment and most likely one that has to be done in the technicians convergence alignment settings not the consumers.
Feb 22, 2007 | Panasonic PT-47X54 47" Rear Projection...
Panasonic PT-47X54 47" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
