Question about Tools & Hardware - Others
I have a old Haubold Pn750 k half inch crown staplier which needs a ring set and pin bumper. Where can I find a part supplier if any are still available?
  • 3 Answers
Ample Supply Company stocks Haubold parts. You can contact Roy at royz@amplesupply.com, or call him at 800 982-7100.
Posted on Jul 14, 2011
    Problem Solver:
  • 13 Answers
This machine has been obsolete since 1985, however some specialist Haubold/ITW stockists may still have some spares. It's worth fixing as these were a robust if ill balanced gun. Depending where you are will determine difficulty in obtaining spares but www.apin.ie could be your solution.
Posted on Mar 14, 2011
Testimonial: "Since I have no clue as to where to start looking this is helpful"
2014 ram hemi check engine light on 99 psi oil pressure reading? With a fix. . I was driving along and my check engine light came on but the vehicle ran fine. I noticed in the vehicle info portion it...
ring the dodge headquarters customer service and lodge a complaint
an oil pressure switch is part of the power train and will be covered under the warranty
Just a dealer trying to rip you off
Sep 23, 2017 | Cars & Trucks
I Have a Haubold PN1414G
thats an upholstery stapler via air supply
a compressor and air tool repairer may have the local contact for you
or this answer is on fixya
have haubold kihlberg PN1414G staple gun needing repairs any suggestions...
Jul 08, 2016 | Office Equipment & Supplies
How do i remove rear rim from alko ride on lawn mower
I was unable to find your exact mower, however, most rear mower wheels come off as follows: remove the black rubber cap in the center of the wheel hub. A channel lock plier and one of those paint can lid removers generally works well for removing the flexible cap. You should then see a flat metal horse-shoe shaped retaining ring. One should ideally remove that with a pair of hog ring pliers. These pliers have two pins that fit into the holes on the retaining ring and pull them farther apart. However, if you do not have the right tool, you can usually pry a retraining ring off with a couple of flat blade screw drivers. Look to be sure there is no cotter pin that may need removed. To remove a cotter pin, use a pair of pliers and an ice pick or screwdriver. When you take off the wheel, there will be a piece of metal approximately one and half inches by 1/4 inch on the axle that slides into a little groove directly on the axle. Be careful not to lose it. When you put the wheel back on, you will need to slide that pin which I think is called a "key" back through the hub of the wheel. Good luck.
Jan 04, 2015 | Garden
Wont shoot nail every time pin wont return all the way up
Some reasons the driver/piston assembly won't retract fully:
- damage to the o-ring (LB1003) around the piston
- cylinder (BA0165) is scored badly
- driver (EA0167) is bent, twisted or warped
- o-ring (LB1023) around bottom of cylinder (in groves & covering small holes) is stretched out or out of place.
- Seal (BC0492) at bottom of cylinder & under bumper is damaged or gone
Aug 11, 2012 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
My 1993 Ford F250 driver side door will not shut unless I lift up on the door from the outside. Is it the door hinges that need replacing or what?
You may have to replace the hinges but most aftermarket suppliers have pin and bushing kits to repair your existing hinges. A phone call to your auto parts supplier can probably fix you up for a fraction of the price of new hinges.
When you go about fixing the door, an old bumper jack is the best tool to use, if you have one. It will support the end of the door while you remove hinges and make adjustments.Otherwise you will need a helper. BE SURE to mark the position of the hinges before you remove them so you can put them back on easily. If you don't mark them it can take a looooong time to get them adjusted properly. Hope this helps.
Aug 29, 2011 | 1993 Ford F250
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
I have a haubold-kihlberg PN1414G, staple gun needing repairs, any suggestions? The plunger goes down, but does not return.
You have a broken piston bumper (the nylon insert surrounding the part of the driver blade that is inside the piston. You can purchase the piston on it's own or complete with the driver attached. That'll be it cured. It's a common problem with the G tacker.
May 31, 2010 | Tools & Hardware - Others
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
I had an accident i need a new front bumper, bonnet, front panel and head light my husband wants to try and fix it what tools would he need. or is it a job that needs done professionaly.
simple half inch drive socket set...set of ring spanners ranging from 8mm up to 22mm....size 10 to 16 star screw drivers, a small hammer, and a pair of pliers... job can be done by a novice, just dont rush it
Jul 27, 2009 | 2004 Ford Focus
Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Electric Tools & Hardware - Others
Tools & Hardware - Others Logo
446 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
