I am getting an e54 code on Ge wcvh6600 front load washer. Did test mode and it will not do a test spin
catriver
  • 878 Answers
SOURCE: GE Washer Spin Cycle Problem
gnarly, do you have the updated motor, harness and start cap? If it goes into spin and does this chunk a chunka chunka bit. Take a meter to the white and white/red wire going to the motor. If you have a steady 120V, replace the motor with the new kit. What the motor is doing is jogging between high to low speed. Catriver..post back.
Posted on Oct 18, 2006
dauphine
  • 207 Answers
SOURCE: front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Posted on Apr 20, 2008
SFroese
  • 141 Answers
SOURCE: GE washer WBVH6240; Won't tumble or spin with any kind of load but works fine empty
How about the belt, tensioner, or transmission?
Posted on Sep 08, 2008
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: how to clean out the Pump Filter on front load ge wcvh6600
for other models, like the GCVH6260, you remove the lower front panel, which is held on by 3 screws, and unscrew the filter, which is a round white plastic thingie on the right side. (unlike the video, there is no convenient flip down spout for the water to drain out.) be prepared to catch about a litre of water when opening the filter. a good-sized tray or bowl works, and have a cloth or towel handy to mop up any spillage.
slide it out, clean it, and slide it back in. on my machine the closed position was marked with a blue mark along the edge - it's a nylon plug with a rubber gasket, so apparently it doesn't need to be overtightened. just turn it back to the way it was.
Posted on May 09, 2011
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
Cycle pauses after about 6 minutes. It doesn't want to spin. In test mode, I'm getting error code E46. With tumble test, motor only tumbles in one direction. With spin test, motor won't spin at...
From what I just read if the same model sounds like the motor sensor could be bad It says it should read around 118 ohms at the two yellow wires when disconnected at the board.
Not sure if the motor will have to be replaced if the sensor is bad
the inverter can also be the problem
Google GE front load washer won't spin or tumble for more
May 03, 2017 | GE GFWN1100LWW Washer
I have error E48 on my GE front load washer
you can down load a file to show you how to put your washer into a srevice test mode
at appliance aid .com in the washer repair aid section line 7 you will see "GE LITTEL SWAN FRONT LOAD WASHER" click on that and you will see two down loads one of them will give you
directions and a list of the codes.
Mar 30, 2011 | GE WSXH208A Front Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Reseting of spin / wash cycle
dont know how old, but get those techs back to fix ,call their boss ,call GE and complain
Dec 31, 2008 | GE WCVH6260F Front Load Washer
Constant resetting
it may have a blocked up pump so keeps trying to spin out water.But your under warrenty.call GE they will send some one out to fix that for you
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
