Question about Car Audio & Video
How do I bypass the factory monsoon amp on a 2001 chevy camaro?
  • 242 Answers
Every time I've done an install an a Monsoon system, I've run new speaker wires. It's the easiest way to bypass the amp because I don't believe there's anyway to integrate it. You should be able to locate the constant and ignition wires in the factory harness with a multimeter and tap into those.
Hope this helps
Ray
Posted on Mar 12, 2011
How to bypass a monsoon stock amp in a 2002pontiac grand am gt
After market radio, you have to. Factory radio, you can't. you need the amp. Tell me what you are doing. I can tell you how to bypass it. You do need a volt/ ohm meter and know how to use it.
Apr 01, 2016 | Cars & Trucks
How do I disconnect the amplifier on my 2005 Grand Prix; it makes continuous static noise whether the radio is on or off or whether the ignition is on or off?
Assuming it's the monsoon amplifier it's located under the rear deck about 8 inches away from the passenger rear speaker. However unplugging it will kill all the speakers. The only way to properly bypass it is to run all new wires.
You maybe able to find another factory amp at a salvage yard.
Warning: Most of the Monsoon head units have a 6V offset, making it incompatible with aftermarket amps.
Feb 28, 2015 | 2005 Pontiac Grand Prix
Where is amplifier plug location 2001 explorer
In the rear of your explorer, remove the right rear factory speaker. Look up in the hole exposed. That is where your factory amplifier lives. Whether you are trying to test, bypass, replace, or tap into the factory amp for an upgrade, all the wires are above the factory speaker hole. If you are doing a complex integration, it is fairly simple to remove the plastic panel that covers the entire area. How To Bypass Factory Explorer amp
Dec 23, 2014 | 2001 Ford Explorer Sport
01 camaro stereo wiring diagram monsoon system
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Mar 15, 2011 | 2001 Chevrolet Camaro
02 camaro factory wiring set up
Monsoon or no Monsoon. I have the wiring diagram for a 2002 Camaro with no Monsoon system.
May 26, 2010 | 2002 Chevrolet Camaro
New Monsoon radio turns off and on by its
check the wires and plugs at the rear of the radio are tight.If all is ok.Then have the radio replaced good luck
Nov 20, 2009 | 2001 Chevrolet Camaro
I have a 2001 SS Camaro. When I start my car and the stereo is on, most of the time the stereo cuts off/ turns off but the background lights are still lit and the windows will not work during the outage....
Yes there may be too many amperes being drawn from your battery. The radio will not work if there is not enough voltage and current. The same with the electric windows. Check the state of your battery, Your local mechanic can do this very quickly. Ask to look at the voltage reading when he checks the battery and the voltage should somewhere around 13.8 volts. If the battery is fine you will need to invest in an amplifier to run your stereo as this may be the root cause of your problems. Too many speakers draw alot of current and can play havoc with the cars electronics,
Good luck
Nov 11, 2009 | 2001 Chevrolet Camaro
Hi, We replaced our battery on our 2001 chevy
CK THE INTERNET THERE IS A WAY TO UNLOCK YOUR RADIO
Sep 28, 2009 | 2006 Pontiac G6
Wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
May 05, 2009 | 2001 Pontiac Grand Am SE
Car Audio & Video Logo
233 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
