Question about Dell Latitude C840 Notebook
How do I check to see if the hard drives on a dell latitude c830 are seated properly.
  • Dell Master
  • 6,771 Answers
I had someone bring me a laptop that had been dropped, and it would not boot, it said operational system could not be found. At that point I decided to remove the hard drive and reseated it back into place and press power, the computer booted up without a problem. The point I'am making is that the hard drive can get knocked out of position making things look worse than they really are, if you are having similar problems remove it and re-seat it back into position it will work or it won't.
Posted on Mar 12, 2011
Hard drive cant be located
hello,
first check the cables if they are properly connected then enter in BIOS(F2) and see if the hard drive are recognized if not you should check if your hard drives are compatible with your system i mean the coonection IDE,SATA1,2 or 3.
Oct 17, 2012 | Dell Latitude D810 PC Notebook
Dell e6400 will not switch on
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension lead or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jul 02, 2012 | Dell Latitude E6400 Notebook
I can not get past the blue screen unmountable_ boot_ volume even in safe mode.
You Dell Latitude cannot detect the hard disk.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude D505 Notebook
No boot sector on internal hardware
There are several causes for this. First make sure the Bios recognizes the Hard Drive as the Primary Hard Drive. Second, double check to be sure the drive is properly seated and connected . If these are both done and set properly your drive has either been erased or lost it's master boot record due to a Virus or Error. You can try using the Windows recovery system to recover the boot sector but I would simply use system recovery and format the drive and reload it to factory specification.
Nov 12, 2011 | Dell Latitude 110L Notebook
WHY IS MY LATITUDE C610 NOT REBOOTING
do any lights come on at all?
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps
Jul 04, 2011 | Dell Latitude C800 Bios Battery (IMP61135)...
Dell Latitude C610 doesn't recognize hard drive
when you took out the old hard drive
there is a black hard drive connector
this would have holes to push on to the new hard drive
without this, it will not plug into the motherboard
be careful if one of the pins breaks the hard drive wont work
Jul 21, 2009 | Dell Latitude C610 Notebook
Dell latitude laptop f1 error message
i think your cmos cell is not working properly.
refix it or replace it.
it is back side of laptop,
Jan 01, 2009 | Dell Latitude C640 Notebook
C610dell latitude laptop does not recognize hard drive
if it is not detected in bios ..then it might be a bad news for u check tthe same in a difrent laptop ..it is being detected ,,,then it is good ,,,other wise replace the hdd
Aug 17, 2008 | Dell Latitude C610 Notebook
Dell d600 latitude laptop
Hi
Dell Latitude D600 can only accommodate one internal hard drive. You can however install a 2nd Hard Drive as a drive module.
Check the picture below. The HDD Drive Module fits in in place of the CD/DVD Drive.
Let me know if further is needed.
Mike
Jun 07, 2008 | Dell Latitude D600 Notebook
Dell Latitude C840 Notebook Logo
56 people viewed this question
Alun Cox
