Question about Kenmore Side by Side Refrigerator
Compressor is running but temp. is not below 29 degrees freezer and 59 degrees refrigerator. condenser coil is a little dirty not bad. suction line feels cool discharge line is hot.
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Sounds like you checked the big things... reach in the back of the freezer compartment and press against the evaporator access cover. Your feeling for a block of ice over the evaporator coils. If your sure that the evaporator coils are not blocked then test the door switch... make sure the light goes OFF and the evaporator fan goes ON when the door / light switch plunger is depressed. If you have in door water and ice you can also test the switch for operation by holding the door / light switch plunger depressed and filling a glass with water. If that does not work either with the plunger depressed then the door switch is bad. I did not see you comment about the condenser fan.... If it is not running or working properly the chassis will be VERY warm to HOT on the face of the chassis where the door gaskets mate to the chassis. Dirty condenser coils will also cause the very warm to HOT front of chassis condition.
Still can't find anything wrong:
- Do a manual defrost: Unit unplugged with an external fan directed into the freezer compartment with the contents removed for 2 hours. (Yes makes a mess)
- Return the unit to normal service after your manual defrost session
- Check initial temps making sure that they return to normal in 8 hours. .
- After 3 days watch temps to see if they are again rising. If they are rising you most likely have an automatic defrost problem that can be caused by the defrost heating element, defrost control or possibly the bi-metal defrost thermostat that is open above 60 Deg F and closed below 60 F.
These are the basics... without a model number my response was generic. With a model number depending on your response there might be other things to check.
Thanks for choosing FixYa,
Kelly
Posted on Mar 12, 2011
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Temp on fridge is 59 and won't go down to 36 as it usually is
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Sub-Zero Refrigerators
Refrigerator runs but does not cool properly. Temp in freezer is 34 degrees, temp in refrigerator top is 70 degrees, and at bottom is 55 degrees.
heatman101
Jul 08, 2011 | GE GSS22IFR Side by Side Refrigerator
Starting this morning frrezer will not drp below 19 degreed and frid is at 48, lowered the temp and still nothing
heatman101
Jul 07, 2011 | GE Refrigerators
Frigidaire model PHSC239DSBO does not cool properly in both the freezer and refrigerator. The freezer temp will not go below 32 degrees and the refrigerator will not go below 53 degrees. Suggestions???
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 15, 2011 | Refrigerators
Side by side unit. no temperature control in freezer or fridge temperature of fridge is 60 degrees F on top. Freezer temp is 45 degrees. Bottom part of fridge is 28 degrees F.
Refrigerator
heatman101
Feb 13, 2011 | Frigidaire PLHS267ZA Side by Side...
UNIT RUNS BUT WANT COOL BELOW 50 DEGREES... COMPRESSOR IS RUNNING AND COLD LINE COLD ,HIGH PRESSURE LINE HOT BUT WILL NOT COOL BELOW 50 DEGREES.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Haier HSB03 Compact Refrigerator
GE Profile Arctica top freezer: freezer and fridge have been too warm all day. The freezer is 40 degrees and fridge is 46 degrees. Adjusting the temp does not help. Please help
Hi,.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
heatman101
Sep 26, 2010 | GE Profile Arctica Stainless Steel Top...
Hotpoint CTX18CPNR freezer over refrigerator set on average but inside temp won't go below 42 degrees F. and runs constantly.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 29, 2010 | Hotpoint HSS25GFP Side by Side...
Samsung refrigerator Not cooling below 45 degrees
heatman101
dffg
Mar 14, 2009 | Samsung RF265AA Bottom Freezer French Door...
Kenmore Side by Side Refrigerator Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
