Both air conditioner units are running but they are not cooling
After additional research, I called the power company. A transformer was being replaced on our street. After the initial email, several appliances started to partially fail (i.e., stove clock worked but burners did not, ceiling fan light worked but fan would not, lights dimmed).
Posted on Aug 03, 2008
My window unit is not cooling my bebroom even at 80 celecius. It is running and but is not that cool.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 06, 2011 | Fedders A6Q10F2B Q Chassis Room Air...
ERROR CH46
if you have multiple unit running from one compressor then you get this code when you set one unit to heat and another unit to cool. All units running from a single compressor need to be in the same mode.
Apr 17, 2011 | LG Art Cool LA121HNP Split System Air...
Compressor is running but ac not cooling
The unit leaked the refrigerant and so it does not cool even though it is running... Here is a tip about troubleshooting your air conditioner...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Royal Sovereign ARP9011TL Air Conditioner
I have a 6 year old Goodman ClJ24. Today I noticed that the motor in the unit was running backwards.Instead of blowing out hot air from the top, it was sucking in air. Also unit suddenly is not cooling.
Yes, once in a while the motor will just start to run in reverse...this is not fixable... you will need to replace that motor...and as you can see if it is not running correctly you will not get proper cooling...
heatman101
Sep 15, 2010 | Goodman CKL24AR24 Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
May 30, 2009 | Amana Comfort Zone 12M32PBEH Air...
Fedders window unit won't blow cool air
Hi There,
It needs to be re-charged with freon.
Mar 28, 2009 | Fedders Q Chassis AEQ08F2E Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
