Question about Astoria Argenta SAE-2 Espresso Machine
Gloria two group Astoria was shooting steam the other morning we turned it off what could this be from?
    President:
  • 1,618 Answers
Where is the steam coming from, if its from the top, then the problem is the vent valve or the safety valve, if it is the safety then the pressure stat needs to be replaced because it might be damaged or blocked at the tube that connects it to the boiler.
Posted on Mar 14, 2011
What amperage does my astoria machine require?
2GR 19.6 amps- 3GR 24.9 amps - 4GR 31.6 amps -->> This INFO From the site .........
http://prima-coffee.com/sites/default/files/astoria/automatic/plus-4-you.pdf
Rapallo - 18.2 amps
Gloria AL2 ...21.7 or 17.8 amps FOR 120 or 230 volts
If that is not the answer go tot he PRIMA-COFFEE site and dig in!
Aug 24, 2014 | Astoria Coffee Makers & Espresso Machines
I have a Astoria Argenta and one of the groups is not working. If there is a blockage, how do i get to the problem.
basicaly all you can do is unplug machine, turn off the water and cool machine to cold. then take apart the group head working back to the boiler till you find the blockage.
Aug 31, 2011 | Astoria Argenta SAE-2 Espresso Machine
I have boiler pressure and steam coming threw the wands but no water flowing through the brew heads. What could be the problem?
Either the solenoids are damaged or blocked, or the metering jet on the top of the group is blocked, or the blockage is at the flowmeters. Do you get a reading on the pump pressure gauge when the buttons are pressed?
May 27, 2011 | Astoria Argenta SAE-3 Espresso Machine
My 2 group astoria over steams from top of boiler.it warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Jan 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
ASTORIA.. PREVENTIVE MAINTENCE SERVICE ? STUART FL OR REPAIR SHOP
The most that you need for PM on you machine is group gaskets every 4-6 months, those are very easy to do. A vent valve every now and then and maybe lubing steam valve swivels. If its Ok with you I will send you my e-mail and if you have any questions you can write me or post on this site. I'm on every couple of days.
Aug 25, 2008 | Astoria Argenta SAE-2 "Big Gulp"
Older machine needs repair
When you press the dispense button does the needle on the dispensing pressure gauge move up to the green area? If so, most likely your group head solenoid valve is bad. It's located behind the back splash. It's a small black box connected to a metal tube just behind the group head. They cost around $70.
If the needle doesn't move it could either be your pump or motor. Now you're in the $200 range.
Jul 06, 2008 | Astoria Argenta AEP/JUN Coffee Maker,...
Astoria Argenta SAE-2 Espresso Machine Logo
93 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
