Question about LG DLE3777 Electric Dryer
Will not get hot. takes 4 hours plus to dry towels. Dryer get warm but not hot
  • 1 more comment
  • jrg2626 Mar 12, 2011
    where could i get an element and what about should one cost
    Canyou answer my reply
    Thanks. Thats what I thought. I'd like to find a service manual so I could check fuses. But they seem hard to find,
    Genius:
  • 1,114 Answers
It sounds like the heating element is going out. After a dryer has been used over a period of time, the heating element that produces the heat to dry the clothes gets old, and does not get as hot as it once did, thus needing to be replaced. The replacement is not that hard, and does not cost as much as a new dryer. If you are familiar with working on appliances, then this should be an easy fix, but if you are not, then I would recommend that you call a repairman.
Posted on Mar 12, 2011
  • Charles Huckeba
    Charles Huckeba Mar 12, 2011
    You will want to shop around to ensure that you get the best deal on the part. You should be able to get one for less than 100.00 dollars. On bizrate, they are 98.00, but again, I would advise that you price shop and that includes repair pricing, as they may be able to offer you a discounted price seeing as they buy things in bulk, or at a discount.
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
Everythings dries fine in my Kenmore dryer except for towels. It takes 2+ hours to dry a load of towels. What could be the issue?
Make sure that the moist warm air from the dryer can escape from the room where the dryer is located and that the Lint filter is clean and, if fitted, the air control vent is fully open.
The dryer needs to get clean fresh air with little or no moisture tro work properly: opening window/door to let the excessive moist air escape will help.
Hope it helps!
Sep 23, 2011 | Dryers
Hours for towels or sheets to dry
a dryer can only handel so much if you over load it it cant tumbel the load inside of it so the warm air wont dry them out,,,also what is it set on??? low or hight heat?? how wet are the sheets when you put them in the dryer??? is the dryer getting a good air flow,, it need to breath in lots of air,,,,and that hot wet air need to get out freely,,,if its even slightle blocked the dryer cant work well,,,how often do you clean out the dust filter in the dryer,,,(this should be cleaned every time you use it) also if the sheets just tiy them selfs into a big knot they wont dry
i hope this was of help to you
Jun 27, 2010 | Asko T712 Electric Dryer
It take 4 cycle to v dry towels or jeans then
Remove all air restrictions and clean out the lint chute. I am supposing you have already done so. Since it does heat a little I am thinking the ignitor flame sensor and fuse are all good. So that leaves these operating coils.7942d84.jpg With a little age they get iffy. Feel the coils if one of them is very hot that is the bad one. In rare cases this flame detectoref9f9ec.jpg will work and then take fifty forevers to work again. The bi-metal gets brittle and takes longer than the norm to cool down and close for ignitor operation.
Lets review: The power comes from the closed control689f826.jpg and limit.fdc9a7a.jpg
the ignitor hogs all the juice and gets screaming hot till the flame detect opens and kills power to the ignitor. This frees up juice for those pesky inter-mittant coils to energize. Any of the above componets are wank and she don't dry right.ffc3f7f.jpg
Dec 18, 2009 | Estate TGDX640JQ Gas Dryer
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer seems to be hot, however it takes forever to dry a load. Is 3 -4 hours normal to dry towels?
Your heater coil has burned into 2 parts. Find a friend WHO IS KNOWLEGABLE about dryers, Call a repair man or find a good used dryer. I understand this isn't what you wanted to hear, but this involves lint and 220 voltage. NOT to be taken lightly. The coil will cost around $50 and the repair men will be a minium of $75; Look in the paper and buy another one....
Aug 25, 2009 | Dryers
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
It now takes 2 hours to dry towels
lets hit the eazy button first.dry a load with out the venting[wont hurt a thing]if ok its the house venting,if not dryer .GE is only brand that has two elements.so if not ge and heating element ok and its blockage in the dryer.hope that helps God bless ,tom
Jan 04, 2009 | Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
LG DLE3777 Electric Dryer Logo
294 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
