Question about Cameras
When I go to take photo a box appears in the rear window saying CARD LOCKED. How do I remove this?
  • Cameras Master
  • 6,771 Answers
Remove the memory card from the camera, look along the one edge for a tiny switch, slide it towards the contacts to unlock the card, the switch that is furthest from the contacts is in the lock position to prevent deletions of your photo's. Now! if the switch is in the unlock position, slide it back and forth to reset the card, if it fails replace the card.
Posted on Mar 12, 2011
  • John Cunningham Mar 12, 2011
    There should be a small door on the bottom of the camera that houses the battery and memory card, it should show a small arrow in the direction it slides out.
Can I get my Finepix software to run on Windows 8?
Consider NOT using the FinePix software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you an use any photo cataloging program such as Windows Photo Gallery or Picasa.
Oct 30, 2012 | FUJIFILM Cameras
Import window in windows 7 does not appear to import pictures from camera
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Aug 23, 2012 | Samsung SL600 Digital Camera
I have taken some new photos on my camera but when I have connected it up to the pc to transfer the photos it keeps saying no new picutures or video were found on this device
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 27, 2012 | Ricoh Caplio GX Digital Camera
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
I just buy a Nikon CoolPix s3000.When I put the USB [with the camera] in the PC,the PC not read the photos.Is says 0 of 0 photo.I use a Windows XP.Sometimes appears a box which says:Camera connected.Select...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Mar 27, 2011 | Nikon COOLPIX L18 Digital Camera
Windows 7 will not transfer photos from camera. it says no photos detected
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 01, 2010 | HP Photosmart M417 Digital Camera
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
On vacation, removed the photo card and it now says LOCKED. HELP
Hi!
If you are using an SD or MMC card, check if the lock button (on the side of the card - a tiny plastic that you can slide) is on the LOCK position. Slide it to UNLOCK position. If it's already in UNLOCK position, slide it to LOCK , then UNLOCK position.
Good luck and have a nice day!
Dec 02, 2008 | Casio Exilim EX-Z750 Digital Camera
Locked on card protect
pp.5-6 of your manual has the information on locking/unlocking
Apr 18, 2008 | VuPoint DV-DV1-VP Camcorder
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
