Question about Toro Lawnmower 20099 Mower Mowers Lawn
10% Ethonol Mix, can I use in Masspot Quattro-40? Thanks. Mark
    Novelist:
  • 144 Answers
Hi azizmark2,
The manufacturers suggest no ethanol mix and only regular gas, no high test gas. I hope this helps you out. Regards and good luck.
Posted on Mar 12, 2011
I have a 2000 audi a4 quattro with a 1.8t motor something blew apart and caused it to drain every bit of the antifreeze outta my car so what's a antifreeze I can get fast to put in it so it's not sitting...
Any antifreeze that has ethelene glycol in will do . For freezing conditions a mix of 55-60% anti freeze will be required . Castrol concentrate is a good one and mix it before pouring in the radiator. So for a 10 litre system mix 6 parts of antifreeze to 4 parts of water. Work out your requirements like that.
Dec 05, 2013 | Cars & Trucks
Hi im just wondering what the fuel mixture should be for my 1996 rm 250 ? thanks mark
For a 250, you can get away with a leaner mix like 40:1 but I still race a 250 2-stroke from time to time for fun and I run 32:1. More oil = less friction, less heat, better sealing, etc...
Any idea what it was jetted to run? the difference between 40:1 and 32:1 is fairly minimal and if the bike is jetted fairly well I doubt you will tell a difference. If the plug is black it is too rich.
Sep 12, 2011 | 2003 Suzuki RM 250
Gas oil mix for old poulan 295
The gas/oil mix is at a ratio of 40 parts gasoline to one part oil. Please rate my solution. Thanks!
Jan 30, 2011 | Poulan Pro Chain Saw 46cc 20"
What type of oil grade should i use in my 2001 audi 2.8 a4 quattro..this car came with no owners manual,and its time to change..thanks
Engine oil capacity with oil filter replacement = 6.0 litres.
Oil grade for 2001 Audi A4 Quattro 2.8
1. SAE 5W-30 / 5W-40, VW 502.00 - all temperatures.
2. SAE 10W-30 / 10W-40, VW 502.00 - all temperatures.
3. SAE 5W-50, VW 501.01 - all temperatures.
4. SAE 10W-50 / 10W-60, VW 501.01 - all temperatures.
5. SAE 5W-30 / 5W-40, VW 501.01 - bellow +15 Celsius degrees.
6. SAE 10W-30 / 10W-40, VW 501.01 - bellow +15 Celsius degrees.
7. SAE 15W-40 / 15W-50, VW 501.01 - above -15 Celsius degrees.
8. SAE 20W-40 / 20W-50, VW 501.01 - above -15 Celsius degrees.
LONGLIFE engine oil:
1. SAE 5W-30, VW 504.00 - all temperatures.
2. SAE 0W-30, VW 503.00 - all temperatures.
Please do rate my response. Thanks!
Jan 26, 2011 | 2001 Audi A4
What is the right fuel oil mixture???
ok im not a mind reader ,,,so what chain saw is it???? il have a go at this one,,,,,
most chain saws take a 50 to 1 mix if there not very old,,,but thats not all of them,,,ok?
some run on 40 to 1 mix,,,,old chain saws run on 25 or 30 to 1 mix? and very old saws run on 10 to 1 mix,,,,now you see you did not help me not telling me which saw you have,,, did you?
if its a new saw to be safe run it on 40 to 1 oil mix its a two strok so if there is a little smoke then its getrting oil to the bearings so it wont seze up?
Dec 02, 2010 | Garden
Not really a problem - my Pro Mac 10-10 works fine. Need gas/oil ratio AND suggestion on which OIL to use. Thanks
Macs run fine with 40:1 ratio. Be sure to use fresh fuel and a modern synthetic saw oil. Mix it in it's own can and be sure to shake thoroughly just before adding to the tank which prevents oil starvation. Don't make more than a gallon at a time unless your business is sawing. Hope this helps!
Oct 19, 2010 | McCulloch Garden
What kind of oil do a 2000 Audi 2.8 Quattro A6 use?
The engine oil specification for 2000 Audi 2.8 V6 Quattro is:
- Cold climate: 5W/30 or 5W/40 semi-synthetic
- Moderate climate: 10W/30 or 10W/40 semi-synthetic
- Hot climate: 10W/40 semi-synthetic
Long life service = MY 2000 ---->
Engine oil grade: 0W/30 synthetic oil to VW specification 503.00/W12 and turbo engines above 154 kW / 200 PS = 503.01
Oct 17, 2010 | Audi Quattro Cars & Trucks
Have mislaid my handbook and can't remember the 2-stroke fuel mixture. Is it 50:1 or 40:1? Thanks.
What is the machine you are asking about? If you use a good quality synthetic 2 stroke oil, if you mix it at 40:1 you will not have any problems, whether it is a 40 or 50 mix.
Sep 04, 2010 | Garden
What type motor oil for Suzuki RM 250?
The engine doesn't use oil,the only oil it gets is from the 2 cycle oil mix in the gas,the transmission uses 85\90 transmission oil such as bel-ray or others. I would NOT reccomend running 10\40 in the trans...
Apr 28, 2010 | 2003 Suzuki RM 250
Ford explorer 2003 and ethonol fuel
hi over here in australia we have alot of problems with this fuel it goes off very fast and alot off fuel systems rubbers perish with i think its **** could cost u alot more on repairs if u really want to use it use it 50/50 dont use it boats mower small engine where the fuel stays in tanks for long periods thats my veiw
rate my answer thanks
Dec 17, 2008 | 2002 Ford Explorer
Toro Lawnmower 20099 Mower Mowers Lawn Logo
87 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
