Question about Dell 926 All-In-One InkJet Printer
I have a Dell AIO 926 printer. I loaded paper into the feeder and it grabbed the entire stack and sucked it into the printer. Now it is stuck and I cannot get the paper to budge to pull it back out. Please advise how to clear the jam.
    Problem Solver:
  • 9 Answers
In the back side of the printer you will find a removable shaft.. remove that and then try pulling the paper from both the feeding area and the rear side. but remember to remove the cartridges before you do so or you may damage tehm
Posted on Mar 12, 2011
  • 1,516 Answers
Unplug the printer to make sure you aren't fighting with the feed motor. Grab a few sheets from the middle of the stack and pull them out first; they will have the least friction. Repeat until you can get all of the paper out.
Turn on the printer with no paper in it and let the mechanism reset itself to home position.Now try loading it with a few sheets. If it takes one at a time, you should be OK. If it tries to eat it all at once again, you may have a problem with the paper separator (usually a cork square or rectangle located next to the pickup roller), or the mechanism is not resetting properly.
Printer will not feed paper correctly. It only goes so and then bunches up and stops. There does not appear to be any paper jam.
First and foremost, call Dell to make sure that your printer is not still under warranty. If it is out of warranty, then follow steps below:
A: What is happening is the feeder is either clogged with something blocking the path or one of the prongs which grab the paper is broken/faulty. If you are unable to to open the printer and get to the roller to change the feeder, then you will need to go to a local repair shop to fix the issue.
B: If you are able to get to the roller to change the feeder, then you can easily order the part from Dell.
Dec 07, 2010 | Dell 926 All-In-One InkJet Printer
After no problems at all, my Dell 926 AIO printer told me that there was a paper jam, but there was no paper stuck in it. Now, it keeps telling me that there is no paper loaded in it, but there is paper...
if you can, check to make sure nothing fell in it. ive pulled thumbtacks and a banana peel out of printers before. also sometimes the little rubber wheels that grab the paper dont grab as good as they once did. sometimes adding more paper or putting in less paper helps. i had this one printer that started not grabbing paper so once in a while i would get a wet paper towel and kinda hold it aginst the rubber things and like print a blank page so it would spin a little, but thats just me
Apr 13, 2010 | Dell 926 All-In-One InkJet Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Jul 03, 2009 | Dell 926 All-In-One InkJet Printer
C 4180 photo smart printer, not loading 4x6 photo paper
You could try stacking more paper behind it, thereby creating more pressure on the paper feed.
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
Dell Photo 926 AIO "Load Paper" error
Solved myself: I reseated the 4 internal wire harnesses and ribbon cables. None of these were obviously loose, but it seemed to do the trick.
Jan 06, 2009 | Dell 926 All-In-One InkJet Printer
Envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the...
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
~~Cheryl
Dec 22, 2008 | Dell 926 All-In-One InkJet Printer
Lexmark 5250 printer
Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
109 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
