Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Water is filling up very often, seem like is draining constantly how can I fix that?
  • Whirlpool Master
  • 8,220 Answers
Your drain hose should be at least 32 inches above the floor to prevent auto siphoning.
Posted on Mar 12, 2011
Scotsman ice machine
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
I have to constantly do a manual drain which seems
i have the same problem....i would think the inlet valve is leaking....that would be the mechanism where the water supply is attached to the dishwasher.......did you get yours fixed? can you help please?
Oct 10, 2013 | Bosch SHU9915UC Dishwasher
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
It dos not stop filling up water
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 27, 2012 | Zanussi ZWF1430W Front Load Washer
Roper top loading washer RTW440VQ1 will not stop filling up
May 22, 2012 | Roper RAX4232KQ Top Load Washer
Washer doesn't stop filling up
May 08, 2012 | Kenmore Washing Machines
Washing machine constantly fills
May 08, 2012 | Whirlpool Clothes Washer Water Level...
It doesnt stop filling
Apr 26, 2012 | Samsung SW62ASP Top Load Washer
Air conditioner will run for about 3 hours then stops because its full - it seems to fill constantly fast??
Hello my name is Heath it will be my pleasure to assist you. This is normal depending on the amount of humididty in the air the faster it will fill. What you could do is run an external drain line to drain the water while its filling so you don't have to keep dumping the fill pan.
May 26, 2010 | LG LP1200DXR Portable Air Conditioner
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
